Old 03-28-2011, 08:32 PM   #1
Procedure on re painting barge/facia boards.
I have the face of the barge/facia boards sanded to bare wood, I sprayed with a water hose to rinse off to get ready to prime, hopefully it's not gonna be bad to have the bare wood non primed for a day or two, will kilzs primmer be good and would stainning be best or paint, also should I do any kind of treatment to the wood first, like a spray on sealer or a termite treatment, I really dont see any termite damage but I am wondering since the wood is pretty old and has a few good sized cracks should I treat it in any way?
Thanks for any input, Doug
schermd is offline   Reply With Quote
Old 03-29-2011, 05:19 AM   #2
paper hanger and painter
chrisn's Avatar
barge boards?
kilz primer
Old 03-29-2011, 09:42 AM   #3
Are you saying no way dont use kilz?
Old 03-29-2011, 04:35 PM   #4
Super Master Painter
Ole34's Avatar
i wouldnt use kilz either ...........id go with Zinsser Cover Stain oil primer.........that stuff is a proven HORSE !!
Ole34 is offline   Reply With Quote
Old 03-29-2011, 05:12 PM   #5
chrisn's Avatar
exterior primer
still wondering what barge is
Old 03-29-2011, 05:45 PM   #6
Ole34's Avatar
i think hes talkin about the board that the gutters get attached to ........
Old 03-29-2011, 07:13 PM   #7
barge boards?
kilz primer
Barge boards are the the 1x8, 1x10 flat boards that run along a flat roof line. Typically run across the back of row homes.
Old 03-29-2011, 07:18 PM   #8
Give it a good sanding with 80 grit sandpaper, dust it off well, and prime it with a good exterior primer. Work the primer into the wood, don't just lay it on, brush it in. Fill the cracks with caulk after priming. Finish with two coats of quality exterior finish. You'll be okay if it's exposed for a couple of days. I wouldn't worry about termites, they can't climb that high. Be careful around the electrical service, that stuff will jump at you if you get too close.
Old 03-29-2011, 07:32 PM   #9
handpaintedbysteve.com
Hey schermd,
The best exterior primer is oil base and not all oil base primers are the same. Stay with a brand name...Sherwin Williams, Benjamin Moore, Pittsburgh Paint etc. Exterior primers were formulated to dry slowly to allow penetration, that's why you shouldn't use Kilz or latex primers. Give the primer a couple of days to harden, then apply your finish coat, be it latex or oil base.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 03-29-2011, 08:33 PM   #10
Ok, thanks for all your input, barge boards, they are the boards where the gable is, they run inline with the rafters do a search.
Doug
Old 03-29-2011, 09:30 PM   #11
Doug
Barge Board
Definition: Exterior visible flat trim board that follows the rake, the angle of slope of a roof rafter.
row homes have flat roofs, barge boards on row homes run horizontal across the top of the back wall. Rafters run horizontal on a flat roof, side to side, bearing wall to bearing wall. This is where the roof outlet box is, and the electrical service runs it's lenght.
On a flat roof, that barge pictured would be horizontal. I thought it was an easier explanation. But, since you brought it up. Now, go paint em.
Old 03-30-2011, 06:27 AM   #12
Schermd, I didn't mean to sound snippy, but generally, painters are told to go up and paint the gable, or more likely "the A". Not all gables have barge board, which is defined not by its location as much is it's flat and follows the rake of the roof. I used the example I did because I spent a good bit of my life living in and working on row homes, and any one who is familiar with one would be able to immediately recognize the barge. The questioner is another east coaster, and I believe that row homes are more common to the east coat, thinning out as you go west young man.
Old 03-30-2011, 04:49 PM   #13
chrisn's Avatar
Have to say,I never heard that term before
Thanks for the explanation
Not many if any row homes around here
Old 03-31-2011, 07:35 AM   #14
Doug
My thinking too. I usually think of barge rafters though then facia board covering the barge rafter.
Painting Skirting Boards and paint dripped into the tile grout naomit111 Painting 2 11-10-2010 10:04 AM
painting trim and base boards fabian Painting 19 10-10-2010 02:48 AM
priming & painting T&G porch boards GlennW Painting 7 09-07-2009 10:19 PM
Painting Fascia, should I paint the drip edge? PaulR Painting 3 12-19-2008 05:59 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
