Procedure For Painting New Work - Painting - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 10:35 AM   #1
Rewards Points: 340
procedure for painting new work
I am getting ready to paint my 1400' add on.
It consist of
1.splatter drag texture over new drywall
2.FJ trim and 6 panel hardboard doors
and 500' of 4'' WM 48- MDF Crown
3.maple cabinet's to be painted white (65 doors and drawers)
4 . I will be using and airless Spraytech to paint with
what is the best order to begin?
1.paint trim first then mask off trim to paint walls
2. or paint walls and ceiling 1st then mask wall's and paint trim?
3 what is a good technique for painting the cabinet doors while on the cabinets
4 and whike we are at it what is the difference between a PVA primer for new drywall and a product like PPG's SEAL GRIP® Acrylic Universal Primer/Sealer
kt82 is offline   Reply With Quote
Old 03-09-2013, 11:12 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
To be honest, I think this job might be beyond where you are as a painter.
Have you ever sprayed?
Cabs are hard- most pros spend years learning good technique for spraying them. Almost never done together- but the systems to do it right take a while to know and develop.
Spend some time searching and reading on what you are doing here- you will learn a lot.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 3 Users Say Thank You to Brushjockey For This Useful Post:
cdaniels (03-09-2013), jsheridan (03-09-2013), kt82 (03-09-2013)
Old 03-09-2013, 01:34 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
You will spend more time masking and cleaning the sprayer than you will save over brush & roller..
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following 3 Users Say Thank You to Matthewt1970 For This Useful Post:
Old 03-09-2013, 05:27 PM   #4
Rewards Points: 340
i spray on Impervo oil and doesn't know I am not a pro
goes smooth as silk every time.
The Ben Moore store left and all we have close is a PPG store
the manager says I will be happy with the manor Royal latex enamel
I will try some on the doors. It's hard to mess up textured 6 panels
Old 03-09-2013, 05:31 PM   #5
Rewards Points: 340
rolling 6500 sq ft of drywall would ruin my spring break,
the question was--- is a PVA primer better or = to a BIN primer you all are always recommending
or is it in addition to the regular primer
Old 03-09-2013, 05:44 PM   #6
Good you know how to spray.
And where did your question say anything about BIN?
My worry is because you don't really know the difference between shellac based primer ( and how it works) and a PVA, and an Acrylic primer sealer- I have a sneaking suspicion that you are overstating your spray skills.
But who are we to stop you-
Here's a couple of things on the primers.
First- think of primers as problem solvers. There are many different kinds because there are many different kinds of problems.
BIN- is a pigmented Shellac ( uses denatured alcohol to thin) . Best stain killer/ odor stopper there is . Very strong odor to work with, but it will dissapate fast with good ventelation.
PVA-(poly vinyl acetate) just a raw wall primer- some like it, I never use it for anything.
Primer / sealers- usually will give a stronger bond and more complete seal- can be used on many surfaces. And there are many types of this .
You could walk in to the PPG store and ask what is best for bare sheetrock- bet they'd have one for you.
Priming the cabs is a different situation.
Are they new wood or primed or painted?
Want to see a paint co that knows how to do this stuff?
check out the link- he's a guy that posts over on the pro board. These guys have it going on.
http://www.shearerpainting.com/blog/
OK- Found the part I was looking for- look at how they set up the cabs for painting..
http://www.shearerpainting.com/blog/...ugh-sept-2012/
The Following User Says Thank You to Brushjockey For This Useful Post:
kt82 (03-11-2013)
Old 03-09-2013, 11:33 PM   #7
Topcoat also recommends the primer. A straight drywall primer, PVA, is okay for a flat topcoat, but a sealer/undercoater is better for a sheen topcoat like matte, eggshell, satin. A sealer with enamel holdout will not draw the sheen out of the topcoat.
The Following User Says Thank You to jsheridan For This Useful Post:
kt82 (03-11-2013)
Old 03-09-2013, 11:34 PM   #8
Nice links there BJ. Looks like a great outfit.
Old 03-10-2013, 10:40 AM   #9
Rewards Points: 5,974
You might want to talk to your PPG store about a product called Breakthough from what I have heard and read it may be what you need for the cabinets. I can't get it where I am but have not heard anything bad about it.
The Following User Says Thank You to ToolSeeker For This Useful Post:
kt82 (03-11-2013)
Old 03-10-2013, 03:10 PM   #10
My BM store sells a lot of Breakthrough, and for cabinets. I've used it once on an exterior porch floor, real nice product.
Old 03-10-2013, 03:17 PM   #11
You can get PPG products through your BM dealer? From what I have read to spray it the finish for cabinets is super smooth and very hard.
Old 03-10-2013, 03:53 PM   #12
Yes, my BM dealer is not a company store. They carry full BM and a decent line of PPG products.
ToolSeeker (03-10-2013)
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Pulling permits -- getting caught on previous UN-permitted work and effect on taxes jpfulton248 General DIY Discussions 11 01-22-2013 03:58 PM
HELP, Please.. Do I really need this work done???? jeminnick Electrical 34 01-04-2013 12:41 PM
Neighbor's foundation work affect me? Adam Poole Building & Construction 2 10-15-2010 12:02 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
