Problem With Sg3 Paint Gun - Painting - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 12:13 PM   #1
thedockguy
problem with sg3 paint gun
I recently purchased a used Graco 190ES airless sprayer. First I will say that I do not have much experience repairing airless sprayers. My problem is that when the trigger is released, the gun keeps spraying a little (not a drip but a weak spray). This is an SG3 gun. Will installing a repair kit (needle, seat and gasket) correct this problem or do I need a new gun? Thanks in advance.
ozom is offline   Reply With Quote
Old 05-23-2011, 03:18 PM   #2
did you clean it completely when you got it? when I got mine,it did the same thing. there was little paint bits stuck in it causing the valve not to close completely. after I cleaned it and a new filter, it works like new
NWFixer is offline   Reply With Quote
Old 05-23-2011, 03:34 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
i wouldnt replace any parts until you try cleaning it first. prabably old paint stuck in the gun as mentioned before. change the filter in the gun too.
mustangmike3789 is offline   Reply With Quote
Old 05-23-2011, 04:39 PM   #4
thedockguy
Re: SG3 paint gun
Thanks to all for the responses.....will clean the gun and post my results afterward. Thanks again.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
problem - latex paint over oil paint theis96 Painting 3 03-14-2009 12:44 PM
