Problem With Roller Stippling - Painting - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 12:57 PM   #1
Problem with roller stippling
Hi. I started priming my walls yesterday with Kilz oil-base, and noticed the roller left obvious stippling behind, which will show through the finish coat. Besides sanding down the ridges and starting over, are there any suggestions on how to smooth out the surface for the finish coat?
Thanks in advance.
neamb2 is offline   Reply With Quote
Old 11-19-2011, 04:22 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
You could try a rag soaked in thinner if it is not dried too long.
The Following User Says Thank You to chrisn For This Useful Post:
neamb2 (11-19-2011)
Old 11-19-2011, 04:28 PM   #3
Too Short? Cut it Again!
Might use a thicker roller cover and put the paint on a bit heavier. Don't go overboard though. Not that there ever is, but this is definitely not the time to use a cheap box store paint. Go to a paint store and get paint with body to it.
The Following User Says Thank You to user1007 For This Useful Post:
neamb2 (11-19-2011)
Old 11-19-2011, 05:40 PM   #4
ltd
Rewards Points: 536
stippling good ridges bad. a soft stipple from a roller is fine it helps hide imperfections. for smooth dry wall or plaster 3/8 nap cover i like purdy white doves sold at the big boxes and sherwin williams.now the ridges i'm not sure i know what you mean if its roller marks then that's application error and you have to sand them out .
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
neamb2 (11-19-2011)
Old 11-19-2011, 05:52 PM   #5
Gymschu's Avatar
Rewards Points: 838
You're pushing too hard on your roller.......let the roller do the work.......very light pressure......lay the paint on.....don't force it.
The Following User Says Thank You to Gymschu For This Useful Post:
neamb2 (11-19-2011)
Old 11-20-2011, 03:48 AM   #6
chrisn's Avatar
Rewards Points: 394
Thats how to avoid it but he wants to know how to fix it
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (11-20-2011), neamb2 (11-20-2011)
Old 11-20-2011, 09:13 AM   #7
Gymschu's Avatar
Rewards Points: 838
Chris, we all know how to fix it........wallpaper "GLUE" in massive quantities skimmed over the ridges.......
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
chrisn (11-21-2011), neamb2 (11-20-2011)
Old 11-27-2011, 06:37 PM   #8
Chrisn, thanks and follow up question...
Thanks again Chris, I used thinner and the primer with stipples on the wall is coming right off. Before I paint with latex, is there any additional wall prep I need to do? Or just wait til the wall is dry and begin painting?
Thanks again.
Old 11-28-2011, 04:25 AM   #9
chrisn's Avatar
Rewards Points: 394
Thanks again.
Thats i tand follow the rest of the instructions posted, not too much pressure. I would switch to a 1/2 inch cover.
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Roller advice/Surface Issues? gmhut Painting 6 03-10-2010 08:32 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
