Problem Painting Lowe's Pre-finished Trim - Painting - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 12:45 PM   #1
Home Slave
Lazy_Jake's Avatar
Problem painting Lowe's pre-finished trim
I recently bought Lowe's pre-finished Polystyrene white oak trim for around my interior doors. I had the assumption that the finish on these trim pieces were already primed and ready for paint. I started painting one piece of trim and found that the paint did not want to stick to the surface of the trim. The paint would would lay on alright, but the paint would then retract leaving spots all over the board uncovered, as if the paint is not bonding to the surface.
Anyone want to chime in as to what I'm doing wrong before I attempt anything else?
Lazy_Jake is offline   Reply With Quote
Old 11-06-2010, 05:05 PM   #2
(the original)
Rewards Points: 756
The main thing you're doing wrong is assuming.....
Prefinished means exactly that, it's finished and ready to install.
Preprimed means it's primed and ready to be finished with a topcoat.
Obviously the paint you chose is incompatible with the existing finish, so
the choice now is either return the trim and buy preprimed, or prime your prefinished with a good bonding primer so it will accept the topcoat. Zinsser Bullseye 123 will work fine.
ratherbefishin' is offline   Reply With Quote
Old 11-07-2010, 12:22 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yep 1-2-3 should bond and allow any topcoat you want. Personally, I've used this stuff in wet areas to prevent rotting and never had any issues painting it. Of course the paint did not also come from Lowes. I usually use P&L Accolade or Davis Perfection. Neither of them has ever really need primer to coat this stuff.
poppameth is offline   Reply With Quote
Old 11-12-2010, 07:32 PM   #4
Home Slave
Lazy_Jake's Avatar
Ok thanks!
painting trim with semi gloss paint sninny Painting 10 09-21-2012 05:33 AM
Painting Trim? willh86 Painting 4 07-19-2010 11:31 PM
A couple questions (edging & trim painting) cellophane Painting 20 01-14-2010 06:23 PM
painting trim licherg Painting 7 01-21-2009 07:30 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 03:28 PM
