Problem Painting Ceiling! Please Help! - Painting - DIY Chatroom Home Improvement Forum
Old 06-06-2009, 12:43 PM   #1
Hi There!
We painted the ceiling in our spare bedroom when we moved in 7 years ago. At that time there must have been moisture between the paint and the ceiling so when we started to paint the paint "fell off" as we were trying to put in on. Eventually we got the paint to stick some how! Well, now we need to paint again and there are actually moisture bubbles between the paint and the ceiling. They are very noticeble on humid days and kind of disappear when it's not humid!
What can we do before and when we paint to avoid the problem of the paint "falling off" as we paint and also what can we do so moisture bubble will not form again! We have no idea why this is happening the room above our spare bedroom is our bedroom!
Any advise would be great!!!!!
Thanks,
Laurie
p00lbys is offline   Reply With Quote
Old 06-06-2009, 12:45 PM   #2
Learning by Doing
Leah Frances's Avatar
How old is your house? What kind of paint was on the ceiling BEFORE you painted.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-06-2009, 12:50 PM   #3
Our house was built in 1942 and we used Dutch Boy the first time.
I have idea what was up there when we moved it! It was probably pretty old stuff it looked like it hadn't been painted in a long time!
Thanks!
Laurie
Old 06-06-2009, 05:59 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
You have an existing, ongoing, original, or cumulative problem that must be rectified before applying any more coating
Your problem in general does suggest moisture, or could be lack of primer on the raw ceiling, a poor quality coating at some point, or plaster ceilings that have "reached their limit" of amount of coating and will no longer hold a coating
The age of the structure could also suggest a calcimine ceiling "paint" at some point (original or later)...your problems re-painting do suggest that it could be a calcimine coating and that's why your re-paint had issues
Exactly what the problem is would determine your next move
How much does the paint peel back? To another coating (paint or primer), or to a bare surface?
If it's bare, then is it plaster or sheetrock?
Having a room (rather than attic) above the failing ceiling does lend credence to looking for something other than moisture, but is there a bathroom close to the failing room? With maybe an exhaust fan?
Don't re-coat w/o investigating further, as the "fix" depends on the actual problem
slickshift is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Painting at the ceiling edge webtekie Painting 5 09-30-2008 09:52 PM
Fixing a painting problem sbigatti Painting 3 10-24-2007 02:11 PM
Ceiling corner painting williamp Painting 6 06-08-2007 09:28 PM
Painting textured ceiling Unregistered Painting 5 06-17-2005 02:27 PM
