Problem With Kilz 2 Latex Primer - Painting - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 01:02 PM   #1
Rewards Points: 640
Problem with Kilz 2 latex primer
I have kilz 2 latex primer going on new drywall, but part of the area had existing paint and was skimed over and completly sanded to degloss the old satin paint (was valspar latex paint previously)
the kilz primer was sprayed on and went on perfectly on the new walls, the exiting ones though it went on smooth, then started to pull and blotch together like it couldn't get adheasion..
what would cause this? anything that can be done to fix it?
The wall was clean, it was skimmed over with drywall compound, sanded, and cleaned after the sanding to remove the dust...
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 03-04-2013, 01:32 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Tough one- I don't see a problem.
One point though is that when you roll it on, it is mechanically moved around on the surface and gets a better bond than just spraying, which can just lay on the surface.
Lots of pros will backroll a spray, even at the prime coat, for this reason.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-04-2013, 02:27 PM   #3
Gymschu's Avatar
Rewards Points: 832
Not a big fan of Kilz 2 primer for drywall. I prefer an actual DRYWALL primer for that task. As BJ said, be sure to back roll anything you spray for best results. What did you clean the dust off with? Hopefully, just a brush down and a light wet sponge mopping to remove any remaining dust.
The Following User Says Thank You to Gymschu For This Useful Post:
Will22 (03-05-2013)
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Painting latex primer over wood trim Mumsie Painting 5 03-27-2012 11:27 AM
Kilz 2 Latex mini report Plasmech Painting 14 05-21-2011 05:10 AM
Kilz Latex Primer & Aura Finish Coat? HenryG57 Painting 7 06-02-2010 03:41 AM
Kilz Primer Question brookeH Painting 2 01-26-2008 09:06 AM
