Problem With Interior Paint Job - Painting - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 10:39 AM   #1
Problem with Interior Paint Job
HI Guys,
Had some painters do a fairly crappy job on the interior of our new house.
Now finding that we have several issues. One being that I have no way to prove that they only painted one coat instead of the agreed upon 2...
Another being that the dry wall taping (I think) seems to be showing through the paint on our breakfast bar pillar...in fact the paint is bubbling up cracking on that area!
What happened and what should I do?
Thoughts on this?
CheriAlli is offline   Reply With Quote
Old 09-26-2012, 10:55 AM   #2
Gymschu's Avatar
Rewards Points: 502
Your recourse at this time is to call the painters back in & have them explain the process they used to paint your home. Point out in the signed agreement where they promised 2 coats of paint and hold them to it. Usually it's fairly easy to see that only one coat was used as you will see small areas where they missed and the sheen may not be consistent on the walls.
As for the taping issue, that's a drywall problem and you may need to call in the drywallers who did your home to have them fix that. Many painters can do fixes like that but in this instance you may want to get the guy in there who did the drywall to take a look.
Old 09-26-2012, 11:03 AM   #3
yup thought so...if we can get any of these guys to come back it will be a miracle...
life in the berkshires...no body seems to care about customer service here nor do they seem to care about working.
as you can probably tell, we have had a very bad experience with all...but thanks so much for the information.
actually when they were painting...i had them redo several spots...inside and out. i cannot tell if the sheen is right or not as there is so much light inside. we have very large windows.
i have noticed that the surface seems "not smooth" which led me to the idea of only one coat...
Old 09-26-2012, 12:03 PM   #4
Gymschu's Avatar
Rewards Points: 502
Cheri, without knowing all the details, I will have to stick up for my fellow painters. I don't know if this is a new construction project or not, but, if it is, you would be surprised by how many shortcuts builders take to save a buck. Many times painters are asked to get in and get out, slap it on the wall and get it done. Oftentimes we are asked to apply a cheap "builder's flat" paint on the walls & unless the homeowner's are really pushing the builder for higher quality, that's what gets done and the builder pockets the money saved.
The Following 3 Users Say Thank You to Gymschu For This Useful Post:
ltd (09-26-2012), ToolSeeker (09-27-2012), user1007 (09-27-2012)
Old 09-26-2012, 01:34 PM   #5
yes a new build and yes a lot of weird stuff going on...
probably will never completely figure it all out.
just glad that it's done...
now for the fixing of the mistakes.
thanks for your input.
Old 09-27-2012, 07:35 AM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
New Drywall should have had 3 coats. 1 Coat of primer and 2 coats of paint. In a lot of new construction, the touch-up for drywall is not the responsibility of the painter unless otherwise stated in a contract. In the commercial jobs we typically do they just figure in to have the drywall guys come back after we have first coat on and do the touchups. It only takes a couple hours at most to go back and prime and then first coat the touchup spots.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following 2 Users Say Thank You to Matthewt1970 For This Useful Post:
CheriAlli (09-27-2012), joecaption (09-27-2012)
Old 09-27-2012, 07:41 AM   #7
wow there is so much that we laymen/women don't know...
i tried to research everything but since we had such a bad experience building..it all went to h....
thanks so much for the info. though.
Old 09-27-2012, 10:42 AM   #8
Rewards Points: 5,974
Sorry guys I am a painter and it sounds like someone forgot to prime the post that is showing thru she didn't say the drywall was bad just showing thru. And yes a lot of builders are taking shortcuts and using cheap products and methods.
Old 09-27-2012, 05:46 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Most of us giving advise are,
Old 09-27-2012, 09:10 PM   #10
ltd
Rewards Points: 536
or else we all stayed at a holiday inn express last nite
ltd is offline   Reply With Quote
Old 09-28-2012, 08:50 AM   #11
Sorry no offense meant I was referring to the ones saying it was a drywall problem when that didn't seem to be the case.
Old 09-28-2012, 06:21 PM   #12
chrisn's Avatar
Rewards Points: 236
[quote=ToolSeeker;1018391]Sorry guys I am a painter and it sounds like someone forgot to prime the post that is showing thru she didn't say the drywall was bad just showing thru. And yes a lot of builders are taking shortcuts and using cheap products and methods.[/quote]
A lot? Dang near all of um are.
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (09-29-2012)
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
