Problem With DIY Wallpapered Coffee Table. - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 11:22 AM   #1
Problem with DIY wallpapered coffee table.
Ok so I'm new at this, I really wanted to create a work of art with my coffee table. I sanded, primed, primed again & again. Sized the surface. Glued my wall paper. PERFECT. Then... 3 coats of polyurethane. Looking great. Then I decided to do one more coat for good luck and IT BUBBLED! Tiny little bubbles that feel like sand. Is there anything I can do to save my table??
danijane is offline   Reply With Quote
Old 08-06-2013, 11:35 AM   #2
Sorry I can't find how to post this in the right thread from my iPhone.
Old 08-06-2013, 01:19 PM   #3
hmmm
I think your only chance might be to do another LIGHT sanding. If you can get the bubbles without sanding too deep to get into the wall paper then you will have to coat again with sealant. Lesson I learned is never shake or vigorously stir the sealant you use, that's where bubbles come from. Let the can sit for an hour before you use it. Good luck
mindyh2@gmail is offline   Reply With Quote
The Following User Says Thank You to mindyh2@gmail For This Useful Post:
danijane (08-07-2013)
Old 08-06-2013, 10:20 PM   #4
An old Tradesmen
Rewards Points: 6,590
Moved to Painting forum.
Old 08-07-2013, 03:50 AM   #5
If I lightly sand it, will it turn the layer of lacquer white or scratchy looking? Gosh I'm so disappointed!
Old 08-07-2013, 07:02 AM   #6
Rewards Points: 5,974
Lightly sand then with a cloth dampened with mineral spirits wipe the white dust off. Then apply light coat of finish.
Wait something puzzles me you said several coats of poly, then you said lacquer.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 08-07-2013, 11:45 AM   #7
Too Short? Cut it Again!
Use a very fine grit paper like 200-400 grit wet/dry and you can almost polish oil based poly. Be patient though. It is not going to cut as much as more coarse paper.
A woodworking shop will have other options like brass wool.
The Following User Says Thank You to user1007 For This Useful Post:
Old 08-07-2013, 12:17 PM   #8
Yeh sorry I'm new at this. I thought poly & lacquer were the same thing. It's poly that I've used
The Following User Says Thank You to danijane For This Useful Post:
ToolSeeker (08-07-2013)
Old 08-07-2013, 03:06 PM   #9
Rewards Points: 274
Itís fine that you are new, you came here to learn and share and we are here to guide you.
alexjoe is offline   Reply With Quote
The Following User Says Thank You to alexjoe For This Useful Post:
How can I strip this? (coffee table, side molding) L4nce0 Carpentry 7 07-26-2010 11:47 AM
Bonding glass to wood (for coffee table) interferens Carpentry 5 07-14-2010 02:20 PM
Powered outlet on table saw outfeed table? b_corwin Electrical 11 04-12-2010 07:23 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
