Problem With Bmmoresco - Painting - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 09:25 PM   #1
Problem with bmmoresco
Hello,
I painted a ceiling with bm moresco white with no colorant and I left a lot of obvious roller streaks. I primed with fresh start primer and did not have any streaks when that dried, but after the first coat of the paint I see a lot of them. Im using a 1/2 nap purdy roller and painting from a ladder. The paint before I primed was beige and I did not any obvious streaks like I do now with the same lighting.
Think it will improve with another coat? Is there a paint that might work better as I have a few more ceilings to paint? Any advice on techniques to use to avoid leaving streaks would be welcome.
MilfordB is offline   Reply With Quote
Old 11-24-2009, 02:57 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 390
Get off the ladder and get a paint roller extension pole
Old 11-24-2009, 10:33 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
I think another coat will do it. The primer made the ceiling white and then you used a white paint on top of that so you probablt missed some spots you thought you were covering. Very common. I think standing on the ground with a pole will help a lot too.
flame sensor problem junkcollector HVAC 1 12-09-2009 08:19 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 04:57 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
