Priming Walls With Lots Of Repairs - Painting - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 07:35 AM   #1
Rewards Points: 37
Priming walls with lots of repairs
Took my time repairing all the holes and dings on the walls. Walls now have white splotches all over the place. I used joint compound for the repairs and sanded smooth, flat, and feathered. I decided to spend the extra money and bought Sherwin Williams paint and primer. Painted a coat of primer and still see the repairs. Should I use 2 coats of primer on the entire wall? On the other walls that are repaired the same way (have to paint whole house), should I spot prime first, then prime the entire wall so the repairs have 2 coats? Is one coat of primer on the entire wall enough on these repaired walls and move on to 2 coats of finish coat?
Do you prime skim coated walls twice?
kah5683 is offline   Reply With Quote
Old 04-21-2013, 08:09 AM   #2
Too Short? Cut it Again!
You can spot primer the patches before your over all primer coat if you want but if you are using a good primer you should not have to do so. You usually do not gain anything with an extra coat of interior primer.
Old 04-21-2013, 08:17 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
The typical system is one primer, 2 finish coats.
If you are using a higher sheen (eggshell or above) on a critical light wall, sometimes an extra spot helps.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Priming / Painting smooth walls beachfront71 Painting 21 06-27-2012 05:46 PM
Rain seepage stain removal and sealing on bare block walls Peipei9 Concrete, Stone & Masonry 2 03-29-2012 05:37 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Plaster walls? Is it plaster? Lots of ?s UVAjenny Carpentry 6 04-15-2009 10:19 PM
