Priming Smoke Damaged Walls......... - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 01:25 PM   #1
Concrete & Masonry
Rewards Points: 620
Priming smoke damaged walls.........
We have an apartment building where one of the units had a grease fire a few months back. It's been "thoroughly cleaned" by a professional remediation company, although there is still quite a bit of black soot "stuck" to the walls. The rep from the remediation company told me that it's perfectly acceptable, and the primer will take care of it completely. They've suggested using Kilz Original (red & white can) for priming. Now, the more I read here, I wonder if I should be using something else, like a shellac, Zinseer, etc...??? Odor is concern, as there a number of other tenants in the building, but I do have access to a large air scrubber that I can vent to the exterior, but obviously I'd rather not have the odor too offensive if possible. I do have an account at the local Sherwin-William's as well, so that's certainly an option as well. Thoughts appreciated.........
jomama45 is offline   Reply With Quote
Old 03-01-2013, 01:29 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Topic has been covered countless times and the usual answer is Pigmented Shellac- BIN.
Use the search funtion on the bar above and look for BIN- you'll find out much more.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-01-2013, 01:30 PM   #3
cdaniels's Avatar
Zinsser BIN primer.It's a shellac,alcohol base.The smell is bad but it dries fast and the odor dissipates quickly.It is the best product for sealing smoke that I know of.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (03-03-2013)
Old 03-01-2013, 02:53 PM   #4
The odor of BIN shellac is far less objectionable than that of Kilz. Why do think they call it Kilz? And as Cdaniels says, it dissipates much quicker. Plus BIN is the industry standard for smoke odor elimination.
Old 03-03-2013, 12:39 PM   #5
Concrete & Masonry
Rewards Points: 620
Thank's guy's, BIN it is...........
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Caulk on walls, priming, trouble with lines, and more! mrsjande Painting 7 09-10-2009 09:29 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Smoke permeating walls LeviDIY Painting 9 05-28-2009 08:45 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
