Priming A Plastic Sidelight Frame ? - Painting - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 09:37 PM   #1
Priming a Plastic Sidelight Frame ?
The sidelight on my front door has a plastic frame with faux wood texture.
Well, it was painted crappily by the builder's guys, and I hated the fake texture, so I sanded off the paint and 99% of the texture using 100 grit Norton. I will wire brush the last remaining paint off.
What's the best primer for the raw plastic frame?
Thanks guys. I appreciate all the advice so far.
WoodySoCo is offline   Reply With Quote
Old 04-12-2011, 09:48 PM   #2
Super Master Painter
Ole34's Avatar
faux wood texture???? ..............you mean faux wood ''paint'' ????
anywho..to answer your question, use any bonding primer....i prefer Zinsser Cover Stain, oil based
Ole34 is offline   Reply With Quote
Old 04-13-2011, 04:23 PM   #3
Faux woodgrain I guess.
Molded into the plastic.
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
replace plastic door lites tallblonde General DIY Discussions 3 09-26-2010 08:24 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 11:35 AM
Corrugated plastic fixtures tonydee Roofing/Siding 4 07-16-2008 10:36 PM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 02:38 PM
