Priming / Painting Smooth Walls - Painting - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 04:30 PM   #1
Rewards Points: 149
Priming / Painting smooth walls
Hello and thanks in advance.
We are going through the process right now of having all the walls in our house smoothed out.
Bottom floor is now sanded and done ..
My question is, is there a preferred roller to use for prime/paint?
Is it OK to hit the local home depot, get a can of bullseye primer and a smooth roller and go at it?
Any tricks we should be aware of?
I am not looking for absolute perfection here but if there is a step or 2 I can do ahead of time that will make the final appearance better I wanted to ask...
Any advice is appreciated and thanks again.
beachfront71 is offline   Reply With Quote
Old 06-25-2012, 04:36 PM   #2
If you don't aim for perfection then its a waste of time ! You can do it ! Wipe down the walls with a damp sponge to make sure there is no sand dust . I've used bullseye before and it worked well, is there better products out there sure, but for the $ it hits the spot.Have fun and you can make it perfect, good luck !
CopperClad is offline   Reply With Quote
Old 06-25-2012, 04:50 PM   #3
Rewards Points: 13,300
Use a 3/8 or 1/2 nap roller.
A 1/4 nap roller does not hold enough paint and would take far longer.
Paint the trim, then do the cut in around the ceiling with a 2-1/2" quality sash brush.
Roll the ceiling before the wall.
Do all your cuting around the trim, ceiling to wall line and inside corners before rolling.
All of it will take two coats of finish paint for it to come out best.
I happen to like Zinzeer 123 as a primer.
Old 06-25-2012, 04:57 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
I actually agree with Joe! ( You're new here- he gets it!)
Cruise around this site- you'll pick up a ton of info-
there is much more to this "painting " thing than some ( read HD) would have you believe.
There are actually skills involved!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-25-2012, 05:33 PM   #5
It's about time Bush. LOL
Old 06-25-2012, 05:35 PM   #6
...Dude. It's Brush...
Old 06-25-2012, 06:55 PM   #7
Rewards Points: 149
Appreciate all the info..
I think what Joe had mentioned is why I asked the question..
I just primed and painted a bathroom with smooth drywall using the pink rollers sold at HD, if you know the ones I am talking about.
2 problems with those:
1. They are short .. like 8 inches wide
2. If you buy the "smooth" version they hold no paint or primer so it takes a ton of time..
Sounds like I can step up the nap size and still minimize the texture and save a ton of time ...
Old 06-26-2012, 05:44 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Hey Bush, in this very rare instance , I do too. What I don't understand is the insistence about NOT clicking on the spell check, I mean, how hard is that?
Old 06-26-2012, 12:17 PM   #9
Rewards Points: 149
Hey all.
Just checking in 1 more time ...
Purchased Purdy 3/8 nap rollers ..
The Home Depot guy told me I did not need multipurpose primer and told me to purchase PVA Drywall primer since the walls are now bare mud.. (drywaller skimmed w 90 minute/green dot mix then finish coat with green dot)..
Any thoughts on using PVA primer or should I stick to the bullseye/zinzeer ..only diff I saw was PVA was 1/2 the price..
Thanks again.
Old 06-26-2012, 12:28 PM   #10
the Musigician
DangerMouse's Avatar
Originally Posted by chrisn View Post
Hey Bush, in this very rare instance , I do too. What I don't understand is the insistance about NOT clicking on the spell check, I mean, how hard is that?
I'm not gonna say it.... I'm not gonna say it.....
......okay, I'll say it. You misspelled insistence!!!
DM
Old 06-26-2012, 12:45 PM   #11
Hey beach- there are some that think PVA is all you need, and some that think it boarders on worthless. I am of the thought that the first thing to hit a wall is pretty important, particularly if you are going to have more than a flat on the wall. I always use a primer/sealer, and "loosen "it up with a touch of water to get a bit more penetration.
There are many good choices in primers, but I feel pretty confident if it is made by Zinnser.
What that primer is doing is gripping onto the wall and mud, and making the porosity equal . Then your finish coats don't show the banding of the tape seams.
Of all the things different kinds of primers do- just priming new rock really is one of the most basic.
Old 06-26-2012, 04:16 PM   #12
Mr. Paint's Avatar
Look for a roller cover that has "Micro Fiber" technology. My company has had great results with this. Use a 3/8 nap for best results on smooth wall.
Mr. Paint is offline   Reply With Quote
Old 06-26-2012, 05:08 PM   #13
chrisn's Avatar
Rewards Points: 234
DM
Who, Me?
Old 06-26-2012, 05:13 PM   #14
chrisn's Avatar
Rewards Points: 234
Originally Posted by beachfront71 View Post
Hey all.
Thanks again.
Right there is you're problem.
Do NOT seek advise form someone who knows NOTHING about paint and or primer and very little about anything else in the world. You are getting advise here from REAL painters . Why would you even go to Home Depot?
Pva primer is half the cost for a good reason, it is junk
Old 06-26-2012, 07:16 PM   #15
Rewards Points: 149
Thanks,
Went back and got the Zinsser PrimeCoat 2 Primer Sealer ..
Assuming its a good choice..?
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 10:32 AM
painting skimmed walls n224ap Painting 10 07-27-2011 03:45 PM
Prepping plaster walls for painting phantasm72 Painting 11 07-03-2011 06:34 AM
Painting Walls dalcacio2007 Painting 4 06-23-2011 02:08 AM
Painting Walls Red Wazoe Painting 8 12-08-2009 12:07 AM
