Priming/painting New Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 09:38 AM   #1
Priming/painting new drywall
I have some new drywall that I am working on finishing. I have the orange peel sprayed and the walls are primed. I plan on leaving the walls white. Considering that regular primer is white and significantly less expensive than paint, is there any reason why I couldn't just leave the primer on the walls with no paint and just use an extra coat of primer?
jnlson is offline   Reply With Quote
Old 04-25-2012, 02:35 PM   #2
Too Short? Cut it Again!
This question comes up at least once a week and you might search for prior posts and responses.
Primer and paint are two very different things with different purposes. Primer will not leave the same film behind as a primer does. Paint will not seal, adhere and provide an equalized base like primer will.
Cutting to the chase. You want to use a quality paint store paint, not primer, for finish coats.
Paint stores will be running their spring sales about now and you can buy good paint for what you would pay for hideous box store stuff.
Old 04-25-2012, 04:00 PM   #3
Rewards Points: 526
The walls will look better, it will be much longer before you need to repaint, and the walls will clean up much better.
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
Gymschu (04-25-2012)
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
