Priming Over Oil-based Paint 12 Years Old - Painting - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 07:40 PM   #1
Priming over oil-based paint 12 years old
I am repainting with semi-gloss latex interior solid wood doors that are painted now with oil-based gloss. The current paint is 12 yrs old so it has had wear on the gloss, but otherwise no peeling. I would rather not sand if I don't have to. Can I use SW acrylic Adhesion Primer. SW says, "Because of the exceptional adhesion of this product, sanding may not be necessary for most clean, paintable surfaces. Sanding or dulling with an abrasive cleaner is recommended on glossy, hard surfaces for maximum adhesion." If I can use it, is "abrasive cleaner" Ajax? How long should I wait before painting with semi-gloss acrylic? Would you recommend other primers such as Kilz Latex or Zinsser 123 latex?
If I should sand, what grit?
If I can use one of the above primers, any special brush/roller, etc?
Thanks in advance for your assistance.
eblock is offline   Reply With Quote
Old 10-18-2011, 08:01 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
You'll be OK- But you'll be OKer if you give it a light sand. C'mon- it doesn't hurt!
They call us painters, but really its all about the sanding.
Get a fine or med sponge sander- and all you need to do is dull the shine.Then you're good as gold.
Use you're adhesion primer and you have no worries.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-18-2011, 08:30 PM   #3
Too Short? Cut it Again!
I have to love this suggestion. Much of what good painters do is all about prep. So often on jobs I was asked if I was ever going to get around to painting. Not yet I would say.
If your surface is intact, do as suggested. Scuff it up. Then I would advise applying a nice coat of alkyd primer. Alkyd primers are still the great equalizers. You can put either acrylics, vinyls or oils over them.
My second choice would be a high bond water based primer.
You do plan to buy paint store, not box store crap primer and paint right?
Old 10-18-2011, 10:01 PM   #4
Now wait a minute Sds- Even I will buy Zinsser products at Menards sometimes.
But not the topcoat. Ever.
Old 10-18-2011, 10:48 PM   #5
jburd964's Avatar
Rewards Points: 166
I did a door and some cabinets in my first house that had oil base and didn't sand prior to applying water based paint. I completely re-did guest bathroom and painting door and cabinets were the end game, So after painting I cleaned up room that was it. There wasn't much use of bathroom. Then over time I started noticing paint peeling. Ended up having to stripe sand and repaint all bathroom wood work. Sand and prime its slot easier then this results.
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 10-19-2011, 04:16 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Just do what Brush said
Old 10-19-2011, 05:10 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Every minute spent sanding is time very well spent and will show in your finished product. It is not just for scuffing for adhesion but to smooth out any inperfections and paint boogers.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-19-2011, 05:48 PM   #8
chrisn's Avatar
Rewards Points: 228
Paint boogers are bad and need to be severely dealt with.
Old 10-20-2011, 09:35 PM   #9
Thanks for ur input. Will go with the sanding & primer in a couple of weeks when it cools down here in Florida. Will report then.
Tags
latex paint , primer , sanding gloss , semi gloss , sherwin williams
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Lead based paint jenikahula General DIY Discussions 3 03-10-2009 01:08 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
