Priming Over Kilz2 - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 12:41 AM   #1
Priming over Kilz2
I'm remodeling a kitchen in a house I just bought. The previous home owner primed the kitchen cabinets with Kilz 2 but did not paint them. Although Kilz 2 would never have been my first choice for priming cabinets (or anything else for that matter) I'm stuck with it and need to determine how to go forward.
I've messed with the cabinets enough now that I'm pretty confident that the Kilz 2 is bonded pretty well. However, the Kilz 2 is not doing it's job for stain blocking and the cabinets will need an additional coat of stain blocker. In the past I've had good results using Zinsser Bin but I've not used it over Kilz 2. Has anyone here ever tried this? Does anyone have any recommendations?
Krispy is offline   Reply With Quote
Old 12-29-2011, 04:13 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Sand the cabinets lightly( 120 grit), clean , re prime with the bin, good to go.
The Following User Says Thank You to chrisn For This Useful Post:
DrHicks (12-29-2011)
Old 12-29-2011, 01:12 PM   #3
Thank you.
Old 12-29-2011, 05:13 PM   #4
chrisn's Avatar
Rewards Points: 228
anytime
Old 01-01-2012, 05:16 PM   #5
ARC Painting's Avatar
primer has no problem adhering to primer, you'll be fine, and now you just want to block stains while keeping the finish smooth, so just try to lay it on well; and you can sand the primer again after if desired.
ARC Painting is offline   Reply With Quote
Tags
cabinets , kilz2 , zinnser bin
Weatherguard v.s. Ice & Water Shield, Priming first? MB1 Roofing/Siding 6 12-24-2011 12:06 PM
Priming bare wood? Ironlight Painting 14 12-03-2011 05:28 AM
Priming fresh stucco. mfpik Painting 3 10-08-2010 05:15 PM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 04:48 PM
Painted semi-gloss over semi-gloss without sanding or priming -- now what? ShrimpBurrito Painting 7 03-18-2009 07:50 PM
