Priming OLD Plaster Walls! What Is The Best? - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 10:13 AM   #1
Home Remodeler Wannabe
Scotsman's Avatar
Priming OLD plaster walls! What is the best?
Good Morning,
I am currently stripping 8 layers of wallpaper that I KNOW (my grandfathers house) goes back to 1950. The wallpaper is coming off better than I could have hoped for! My question is what to do after I have it all removed? Eventually I will be painting with Latex paint, wash with TSP, wash with clean water, prime, (what type/name primer do you suggest) and double coat. Will be using an egg shell finish. Everything said and done the walls will NOT be perfect, but I need to have at least light scrubbability. (4 and 2 year old grandsons)
Thank You
Scotsman is offline   Reply With Quote
Old 11-25-2009, 10:40 AM   #2
ccarlisle's Avatar
If you are about to paint a previously-wallpapered surface, just make sure the old paste is off - otherwise you'll have a rough surface that no paint or primer will hide. I gather you are not having problems removing the old paper but once you get down to the first layer, there may be paste remnants left on the wall; now fortunately, they use a cellulosic paste back then which is easily re-emulsified back to paste with soap and water. Use a stiff brush or a sponge, perhaps a scraper...
Then prime with the product you choose.
But you say 'old plaster' i.e. cement-based wall treatment that has old paint on top of it. What you would be looking for is a primer that makes the adhesion of the new paint uniform - you don't need a filler because there is already paint on there. So, given you have a smooth, clean surface to start with, scuff it up a bit with sandpaper and wash it with TSP. Then apply a good quality acrylic primer to make the subsequent layers of paint stick well, resist scuffing, are washable and 'jam-resistant'.
Like BMs "Fresh Start"...my favorite.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-25-2009, 11:55 AM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
After removing the wallpaper clean the walls well with tsp making sure to get any wallpaper residue off. Make any repairs necessary to the walls. Apply a good fast drying oil base primer, I usually lightly screen sand the walls after I prime with a pole sander and drywall screen, then apply 2 coats of a 100% acrylic paint.
housepaintingny is offline   Reply With Quote
Old 11-25-2009, 05:58 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Gardz will work just fine
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 09:51 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
