Priming New Drywall Questions - Painting - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 01:37 PM   #1
Rewards Points: 22
Priming new drywall questions
I am getting ready to prime new drywall in a renovated room. Two days ago, I attempted to do all my brush work in the corners with Behr Premium Plus. I returned it once I saw how poorly it covered. I jut picked up SW Multi-Purpose Latex Primer. Hopefully, the results will be better. Any input? I assume this is much better based on how stinking expensive it was.
My question is this. How long after priming can I wait before the topcoat? My wife wants to wait until the flooring and other work is done before picking a color. I have been reading contrasting opinions.
Brett K is offline   Reply With Quote
Old 08-13-2013, 02:11 PM   #2
Rewards Points: 14,312
No such thing as primer and paint in one as you found out or what the can says.
Zinsser 123 would have been my first choice for a primer.
Best in my option to prime and paint the walls before the floor goes in.
Much easer then cleaning up spills and splatter and no chance of a step ladder scratching it.
Old 08-13-2013, 02:16 PM   #3
Davejss's Avatar
Rewards Points: 782
Old school rules are still the best. One coat of good quality oil based primer followed by two coats of excellent acrylic latex.
The oil based primer is smelly and a pain to clean up, but in my experience it is the best choice.
Just my two cents..
I would get it done before the floor. No need for drop cloths. May just need to touch up the base boards if they get dinged up during flooring.
Davejss is offline   Reply With Quote
Old 08-13-2013, 02:44 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Dave- oil on new rock? You really are in the dark ages.
That will raise the fuzz and grain of the paper up so hard it will take real large effort to get it to smooth out.
There are a zillion better choices in quality wall primers .
It also depends on 1) how good the mud job /sanding is, an2) what sheen you wish to finish with.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-13-2013, 02:58 PM   #5
Davejss's Avatar
Rewards Points: 782
I was thinking of skim coat plaster. Didn't read the post well. I'm so used to plaster on my jobs, I haven't used sheet rock and mud in many years.
Old 08-13-2013, 03:04 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
Its fine to wait a while between coats on interior surfaces. Primer on ext surfaces exposed to the weather can deteriorate pretty quickly if not top coated, but its not an issue on walls inside.
For coverage on the Sheetrock, put on a generous coat. Dip the brush and roller often.
Coating thickness is as important (probably more so) than the particular brand of paint.
Even if you get a good coat on, don't count on new rock covering in one coat.
Jmayspaint is online now   Reply With Quote
Old 08-13-2013, 04:45 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
How come you did not just get dry wall primer? Would have saved some $
Old 08-13-2013, 08:05 PM   #8
Painting Contractor CT
Rewards Points: 77
Post
SW products are much better that Behr is, that's for sure. After you have primed your walls, you can wait as long as you need to after the primer has dried to apply top coats. Good Luck!
KD PAINTING is offline   Reply With Quote
Old 08-14-2013, 01:36 AM   #9
chrisn's Avatar
Rewards Points: 616
not necessarily true
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (08-17-2013)
Old 08-14-2013, 07:09 AM   #10
Gymschu's Avatar
Rewards Points: 1,032
The only thing I would add........SOMETIMES, it's best to wait til the flooring is intalled before putting the LAST coat of paint on. Why? Because the flooring guys are going to be leaning against your walls, dinging up spots as they nail in the hardwood, etc. Not saying they can't be careful because some flooring companies are very careful, but, usually they mar the walls up pretty good and then you have to touch up and that's more of a pain than just waiting til they're done to do a final coat.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
Jmayspaint (08-14-2013)
Old 08-14-2013, 09:17 AM   #11
Rewards Points: 22
Thanks for the input everyone! The SW primer is going on nice! A major improvement! I am trying to convince my wife to pick a color to put up sooner. The flooring guy will be careful, since it is me doing everything. I also called SW. They say 2-3 months, but no more.
The room is going to be a photography studio, so my wife is concerned about the color impacting her work.
Old 08-16-2013, 10:47 PM   #12
Rewards Points: 4,796
Not necessarily. Sherwin Williams, like most paint companies, makes some cheap products as well.
jeffnc is offline   Reply With Quote
Old 08-16-2013, 10:49 PM   #13
Once you have painted, you can not get primer under the paint. Whatever is the first material to cover the drywall is the material that will be on top of the drywall forever. A chain is only as strong as the weakest link. If your first link fails, then it can't ever be made up for with later top coats.
Having said that, it sounds like your issue is "hiding", which is no big problem.
Drywall fun + questions BirdSlapper Drywall & Plaster 39 06-07-2013 02:28 PM
Priming & Sealing Drywall in Basement nhoj Painting 31 02-28-2012 03:04 PM
DRywall size questions Mark Harvey Drywall & Plaster 12 01-20-2012 08:37 AM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Have some drywall questions Mikedks Remodeling 20 01-09-2008 09:23 PM
