Priming Needed For Bathrooms? - Painting - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 07:07 AM   #1
Rewards Points: 41
I'm ready to begin prepping two upstairs bathrooms. Each has a ventilation fans and a large drafty window. I want to use a basic white in both and have Sherwin Williams Duration paint. I'm thinking that this is ok for both walls and ceilings in the bathrooms.
I plan on scrubbing the walls and ceilings with a bleach/TSP solution and going over everything a second time with just water.
The existing paint in the master bath has no flaking or bubbling. In fact it looks like done fairly recently, maybe a year or two ago, by a pro (who had to use the yucky beige color chosen by the house's owner).
The existing paint in the guest bath has a few areas where the paint has developed very tiny cracks -- to the extent that in one 12" X 12" square the surface looks like sand. In this area paint comes off as a powder when I rub it with my finger. The paint that's underneath is solid -- no bubbles or flakes and can't get it off (it appears to be latex). I plan on sanding these areas to get rid of all the degraded paint before scrubbing/rinsing/drying.
Do I need to use a primer in either bathroom, and if so, what type should I get? I've been using Kilz in the bedrooms.
Amycat is offline   Reply With Quote
Old 09-12-2009, 08:46 AM   #2
ccarlisle's Avatar
A "need" to use a primer depends more on the surface being painted than it does on what room it is good for, and as a general rule, you should 'prime' a wood, or a bare plaster surface, but 'paint' an already-painted surface (with obviously some exceptions).
But it sounds like most of you bathroom is a painted surface in good condition therefore a "paint" is called for rather than a "primer".
But if you have one chaulky area that may be a bare plaster patch or something, then prime that, and paint the rest. The primer will do what it does best on that patch: seal, and give a better surface for the follwoing coat of paint to adhere to.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 09:15 AM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 04:48 PM
calculating amount of exhaust vents needed bitty071203 HVAC 4 06-09-2009 08:13 PM
Painted semi-gloss over semi-gloss without sanding or priming -- now what? ShrimpBurrito Painting 7 03-18-2009 07:50 PM
Finished priming, but I still see shadows underneath...? yummy mummy Building & Construction 2 02-19-2009 09:15 AM
