#1 |
Priming MDF
I've got some MDF coverpanels I'm working with (access doors that are flush with the wall) that open on hinges ----that over utility meters, shut off valves, etc.
It will be paint grade. Applied 1st coat of Gardz, May do a second. Just knock it down with 120 and paint away right ? |
#2 | |
jschaben
Priming MDFQuote:
John Schaben "Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Priming MDF
I've got 4 primers in my stash....some more than others....
The primers I want to use up is.... gardz , fresh start Premium or Bin Blue. The Bin Red I don't have enough for these panel covers.....but yeah, bin red would have been my 1st choice. The panel doors are flush with the wall (inset). I'l going to scuff it a little later to see how it feels after I light scuff. When I was putting the gardz....I was second guessing and wishing I had the oil down... |
#4 | |
jschaben
Priming MDFQuote:
EDIT - Just got to thinking (not always a good thing) but since the edges are the most susceptible to moisture, just seal the edges with what BIN red ya got and use whatever else for the surfaces.
John Schaben "Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by jschaben; 06-29-2012 at 04:43 PM. |
| Display Modes | |
| Weatherguard v.s. Ice & Water Shield, Priming first? | MB1 | Roofing/Siding | 6 | 12-24-2011 12:06 PM |
| Priming Deep Well Jet Pump | tooshort79 | Plumbing | 1 | 12-12-2011 08:16 PM |
| Priming bare wood? | Ironlight | Painting | 14 | 12-03-2011 05:28 AM |
| Priming Interior Wood Doors | Lovegasoline | Painting | 6 | 09-12-2009 04:48 PM |
| Painted semi-gloss over semi-gloss without sanding or priming -- now what? | ShrimpBurrito | Painting | 7 | 03-18-2009 07:50 PM |
