#1 |
Priming interior wall repaints
When is it necessary and when is it not necessary to prime interior walls you are repainting?
#2 |
I've been painting alot of rooms lately and the only time a wall was primed was after a patch had dried. Using drywall compound priming was a must. Because blistering bubbles under new paint would show up if not used over the patch. Using good paint makes a difference. Not using a primer will show new patch work if a Satin or Semi Gloss is used. I Like SW or BM paints the best.
#3 |
Yeah, I'll do it myself.
Doesn't it depend on the type of wall it is, too? I was always under the impression drywall should be primed as a rule of thumb, but I'm not aware of how it is for other surfaces.
#4 | ||
Tired, Cold, and Damp
Priming interior wall repaintsQuote:
Raw wood and drywall, raw joint compound, mostly found in repairs in re-paints Sealers may be needed for stains Oil paints need primer if going over with latex Glossy paints should have it after sanding...especially in bathrooms Extreme color changes could be a reason Mostly problem areas, like a wallpaper removal, or chalky or flaking old paint, those would need a specialty primer Quote:
They need proper prep, which includes cleaning, sanding, and dusting But not primer |
| Display Modes | |
| Spot Priming or prime everything? | hdtvluvr | Painting | 2 | 09-30-2007 08:32 PM |
| exceptions to priming? | joeyboy | Painting | 5 | 09-23-2007 01:59 PM |
| ? priming ? | warnerww | Painting | 2 | 05-04-2007 11:24 AM |
