Old 05-12-2011, 12:58 PM   #1
In a little over my head
priming hardboard siding
I'm about to install hardboard (Masonite) siding on an addition to my house. It's 12" wide, installed with about a 8.5 inch exposure to match esisting 1x10s. I've been advised to prime the backsides of the boards before installation for longer life.
Do I need to use exterior primer, or would this be a good way to use up some partial cans of paint that are leftover from other projects?
Thanks!
ratherbefishing is offline   Reply With Quote
Old 05-12-2011, 07:27 PM   #2
Anything that will be exposed to the elements needs exterior primer, in this case it would be the cold, so yes, exterior. The idea of backpriming is to create a vapor barrier, so you want the least permeability. To me that would be oil, no latex.
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Identifying Hardboard Siding cowillik Building & Construction 1 06-17-2006 01:12 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
