Priming Fresh Stucco. - Painting - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 05:25 PM   #1
Priming fresh stucco.
I will be painting some new stucco. KILZ2 says it can be used to prime the stucco after a 7 day curing period.
Is KILZ2 good choice?
Is 7 days enough drying time now that the humidity in FLA has gone way down?
Latex over the KILZ?
Can I paint directly without priming?
mfpik is offline   Reply With Quote
Old 10-07-2010, 09:55 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Skip the Kilz2. You can paint directly on the stucco as long as it is a good masonry paint which will expand a bit when it dries.
Old 10-07-2010, 11:11 PM   #3
Rewards Points: 150
Sure. Besides Kilz2 is the worst exterior latex primer on the market. Anything would be better than using that.
hammerheart14 is offline   Reply With Quote
Old 10-08-2010, 04:15 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If you have a Sherwin Williams near by you could apply 2 coats of Loxon XP, or prime with Loxon masonry primer first then apply two top coats of a quality acrylic latex, or apply two coats of Shercrete which is a flexible, breathable acrylic latex and all of these products come in a multitude of colors. You should not paint directly over the stucco without first priming with the proper product or using the right product.
housepaintingny is offline   Reply With Quote
painting stucco sorta myself AdamBNYC Painting 1 08-16-2010 08:17 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
