-   -   Priming fresh stucco. (http://www.diychatroom.com/f4/priming-fresh-stucco-83312/)
mfpik 10-07-2010 06:25 PM
I will be painting some new stucco. KILZ2 says it can be used to prime the stucco after a 7 day curing period.
Is KILZ2 good choice?
Is 7 days enough drying time now that the humidity in FLA has gone way down?
Latex over the KILZ?
Can I paint directly without priming?
Matthewt1970 10-07-2010 10:55 PM
Skip the Kilz2. You can paint directly on the stucco as long as it is a good masonry paint which will expand a bit when it dries.
hammerheart14 10-08-2010 12:11 AM
Sure. Besides Kilz2 is the worst exterior latex primer on the market. Anything would be better than using that.
housepaintingny 10-08-2010 05:15 PM
If you have a Sherwin Williams near by you could apply 2 coats of Loxon XP, or prime with Loxon masonry primer first then apply two top coats of a quality acrylic latex, or apply two coats of Shercrete which is a flexible, breathable acrylic latex and all of these products come in a multitude of colors. You should not paint directly over the stucco without first priming with the proper product or using the right product.
