Priming Damp Wood? - Painting - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 08:41 AM   #1
Rewards Points: 41
Priming damp wood?
I just built a shed and it's time to paint it but the weather is not cooperating. I planned to hit it today with oil based primer, knowing that it was going to rain tomorrow. What I didn't expect was some light rain this morning.
I imagine the wood will be dry on the surface by this afternoon but I don't know how this will affect the adhesion and durability of the primer. Any thoughts?
kboorman is offline   Reply With Quote
Old 11-15-2010, 07:57 PM   #2
Paint Store
you really should wait 3 days after rain before using an oil primer. it just doesnt adhere well to raw, wet wood. you can literally peel off oil based paint/primer that has been applied to wet wood.
you might be able to borrow a mositure meter from your local paint store that can help you to determine when you can paint. or you may look into getting a water based primer. Water based primers do not work as well on raw wood, especially if its redwood or cedar, but you can use water based primers on wet wood on a dry day. you just need to dry it to the touch with towells or cloths, and point a fan at the side of the shed your are painting.
if you used brand new wood that still has a mill glaze on it, you might just be able to wait until you get a nice week of weather, even if thats not till early spring.
DCCenter is offline   Reply With Quote
Old 11-16-2010, 02:35 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
I don't think I would be applying ANY primer,oil or latex, till it was COMPLETLY dry. I don't buy the statement that you can apply latex after just towling dry. You MIGHT get it to stick but why take the chance?
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
