Old 08-08-2012, 01:15 PM   #1
priming before spackling plaster
Do I need to prime very old but stable plaster walls before i spackle? The eight year old paint has crackled in several areas in a bedroom, mostly on walls that butt against bathroom and exterior walls. The plaster appears dry. Also, is there
a special primer i should use in case it has to do with dampness? I am using latex satin paint and kiltz primer, I think it is the mildew resistant product.
handychickcyc is offline   Reply With Quote
Old 08-08-2012, 05:01 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
What I would be asking is what caused the cracking. Is there staining around it? is it flaking? is it a crack in the plaster, or just the paint?
Different solutions for each.
But to directly answer- you would not need a primer first but after yes, and which Kilz ( not Kiltz BTW..) do you have- the original oil?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
handychickcyc (08-08-2012)
Old 08-08-2012, 05:47 PM   #3
paper hanger and painter
chrisn's Avatar
which should be the ONLY one used
Old 08-08-2012, 06:31 PM   #4
Thanks, i went to SW and they recommended oil based primer.
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 09:28 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 10:12 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Priming OLD plaster walls! What is the best? Scotsman Painting 3 11-25-2009 06:58 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
