Priming After Wall Paper Removal - Painting - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 09:35 AM   #1
Priming after wall paper removal
Hi
I have few paint projects ahead of me.
1. I will try to skim coat plaster walls with magic trowel. Putting thinned joint compound on the wall with a roller and then going over it with the trowel.
2. In two rooms I need to remove wallpaper from the plaster walls then skim coat and then pain.
My questions are
1. I read that I should paint the plaster with semi gloss paint prior to skim coating with the joint compound for better adhesion? Any experience with this step?
2. After I skim coat the rooms that had wallpaper what type of a primer I should use? Should I use an Oil based primer to seal the surfaces or should I can I use Gardz primer? My consern with oil based primer is the fact that I have to wait 12-24 hours for it to dry before painting.
Thanks,
keano016 is offline   Reply With Quote
Old 09-14-2009, 03:13 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 472
# 1 I never head of that, but it does not sound right to me. The semi gloss surface would be pretty glossy for your compound to stick too.
#2 Gardz is correct.
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Tar & Felt paper removal bhc65 Roofing/Siding 3 02-28-2007 03:12 PM
