Primimg Over Drywall Skim Coat - Update - Painting - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 06:59 AM   #1
Primimg over Drywall Skim Coat - Update
I wanted to thank those who gave us some advice on my earlier post and to say that our Walls look great.
It is work and a dusty job but we feel it makes the Paint Job look good.
Now we used a ready mix drywall compound and a second coat was used in specific spots and a couple walls only.
We need to Prime now so what brand would you recommend. Ben Moore was suggested is that a good cover for Drywall Mud and also for older painted wood?
This is a great DIY Forum
chisels1 is offline   Reply With Quote
Old 10-10-2010, 07:15 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
YES
chrisn is online now   Reply With Quote
Old 10-10-2010, 10:29 PM   #3
Rewards Points: 150
any good quality PVA primer will do.
hammerheart14 is offline   Reply With Quote
Old 10-10-2010, 10:57 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
PVA is an evil product that should be taken off the market. Every time I have used it it looks like nothing was even put on the walls and your first coat of paint will still soak into the drywall like nothing was even on there. Benjamin Moore fresh start, Sherwin Williams Promar 200 primer, or Zinsser 123 is what I would go with.
Old 10-11-2010, 02:10 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I have to agree PVA primer is garbage. Usually on new drywall we use Sherwin Williams Promar 200 primer or there Problock primer
housepaintingny is offline   Reply With Quote
Old 10-12-2010, 04:11 AM   #6
Rewards Points: 150
Funny, it's always worked for me. You can always overkill it and use a better primer.
Old 10-12-2010, 12:10 PM   #7
Rewards Points: 616
Its not overkill if you want a nice uniform finish that will last a long time. Any quality paint job starts with quality prep work followed by quality materials. After you prime new drywall you should sand the walls with 120 grit drywall screen.
Old 10-12-2010, 03:42 PM   #8
doesn't this kill the texture?
racebum is offline   Reply With Quote
Old 10-12-2010, 04:16 PM   #9
Rewards Points: 616
No, the metal sanding screen will cut any boogers and so forth off of the wall and give a smoother finish for your top coat to be applied to. You just give it a quick hand sandind with the screen on a sanding pole.
Foundation Skim Coat kwikfishron Building & Construction 4 07-26-2010 06:37 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Drywall taping and skim coats helpless handyman Painting 7 08-11-2006 09:09 PM
drywall nightmare DIYNovice General DIY Discussions 6 09-25-2005 08:20 AM
