Primer Wont Stick To Semi Glossed Wainscoting?? Best Way To Remove Primer? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 10:51 AM   #31
Originally Posted by wantboost View Post
What about all the even surfaces then
It's hard to say now. You can spackle the small spots where the old layers came off and use joint compound (after properly preparing the surface) for the larger ones. If too much of the wall is like that, then you could remove the paint by using a putty knife or the pads you already used. Or, if the unevenness isn't that bad but it's in a wide area, you could use the 3M finishing pads that I mentioned.
Dorado is offline   Reply With Quote
Old 03-30-2013, 12:28 PM   #32
Rewards Points: 5,974
You do understand this is wainscote not the whole wall? And is probably wood though does not have to be.
Old 03-30-2013, 12:53 PM   #33
Yes, and after rereading the top post it's probably a small enough section for joint compound. Removing layers of paint from an entire lower section of a wall may be more trouble than it's worth but it's hard to tell exactly how poorly the paint is sticking.
Old 03-30-2013, 01:02 PM   #34
Even if the wainscoting that's affected is a single panel, removing the paint on only that panel would be kind of weird because the adhesion on the other panels would be no better. I think I'd patch it, but the kind of wainscoting is another thing we don't know.
Old 03-30-2013, 11:11 PM   #35
Rewards Points: 145
i just the squares boxes on top of drywall. i thought it was true panels.... whats the best way to get the surfaces even on the detail work of the wainscoting...
thx
wantboost is offline   Reply With Quote
Old 03-31-2013, 10:02 AM   #36
Home Depot sells a deglosser product which works great on hard to adhere surfaces:
Mr sparkles is offline   Reply With Quote
Old 03-31-2013, 10:16 AM   #37
Rewards Points: 145
thankyou. buy im past that stage. i have wainscoting thats all messed up
Old 03-31-2013, 11:19 AM   #38
The options have already been mentioned but I'm not sure which the best one is. If you start stripping more paint you may have to strip it all to be satisfied. I'd try to patch even a curved surface if the unevenness is in a small area.
Old 03-31-2013, 03:02 PM   #39
Deglosser
I've had walls with gloss oil paint on them and primer just peeled off.I purchased a deglosser product frm homedepot.Just wip area down and let dry , need no primer just top coat. Good luck
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
How to remove primer from cabinet diy.wannabe Painting 3 12-28-2012 09:00 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
how do I remove purple primer from white linoleum floor? amerigoplumbing Flooring 5 04-09-2012 07:22 PM
