Primer Wont Stick To Semi Glossed Wainscoting?? Best Way To Remove Primer? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 12:17 AM   #16
Rewards Points: 145
correction: Behr premium ultra plus semi gloss was used on the wainscoting directly on top of the previous semi gloss finish. i let u cure for 5 days and still peeling off when it gets wet.
wantboost is offline   Reply With Quote
Old 03-28-2013, 12:47 AM   #17
Scrape as much off as you can with a wide putty knife or something similar. Clean the walls with TSP substitute (you mainly want to clean the old surface that you exposed). If there's still new paint on the wall that doesn't stick well, remove it with stripping pads like Brushjockey showed you then clean the wall again with TSP substitute. Sand, then clean the wall again with TSP substitute and paint. Most people would probably skip a step or two. It's up to you.
Dorado is offline   Reply With Quote
Old 03-28-2013, 06:17 AM   #18
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
maybe part of the problem???
Primer wont stick to semi glossed wainscoting?? best way to remove primer?-behr1.jpg
Old 03-28-2013, 06:58 AM   #19
ltd
Rewards Points: 536
with out seeing who really knows. I can tell you, with no prep at all, I have painted semi behr over semi behr over some questionable surfaces, as in rentals and have never had a problem .you can say what you want about that behr but it does stick .,
ltd is offline   Reply With Quote
Old 03-28-2013, 07:52 AM   #20
Gymschu's Avatar
Rewards Points: 180
Uh-oh, Chris, you are going to anger Jagans the roofer who wonders why "so-called professional" painters are afraid to use Behr paint..........read thru the posts and now you can understand why we "so-called" pros avoid Behr like the plague.
Gymschu is online now   Reply With Quote
Old 03-28-2013, 10:41 AM   #21
Rewards Points: 5,974
BEHR ULTRA and it didn't stick WOW how could that happen?
Old 03-28-2013, 05:10 PM   #22
chrisn's Avatar
Rewards Points: 120
Old 03-28-2013, 05:11 PM   #23
chrisn's Avatar
Rewards Points: 120
I replied to the roof master in another thread
Old 03-30-2013, 12:30 AM   #24
Rewards Points: 145
so i tried using this pad and i created a big mess. Ive got other layers of paint peeling off and lots of uneven surfaces???
Originally Posted by Brushjockey View Post
No-
These-
Old 03-30-2013, 01:11 AM   #25
If the remaining paint won't scratch off with your fingernail then you just need to smooth out the surface. I hate 3M for not providing documentation or even a large enough image of the product to read the packaging, but they also make a "Final Stripping Pads" that are like 0 steel wool. That will be less aggressive and even things out at least a little.
Old 03-30-2013, 01:34 AM   #26
Rewards Points: 145
There's paint that still can be peeled off
Old 03-30-2013, 09:58 AM   #27
The thing is if paint is still peeling off it is not bonded so it has to come off or whatever you put on it will also come off.
Old 03-30-2013, 11:06 AM   #28
If it can be then just try to not let that happen. You were satisfied with the old coats so I don't think you have to worry that more paint can be pealed off. You probably just have a thick coat of paint that adheres to itself better than to the wall. That doesn't mean it's not stuck to the wall You mainly have to remove the paint that's not stuck to the wall. A putty knife or some other scraping tool is the best way to remove unstuck paint. The pad is best for removing it all.
Old 03-30-2013, 11:32 AM   #29
HUH
Old 03-30-2013, 11:38 AM   #30
Rewards Points: 145
What about all the even surfaces then
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 06:03 AM
How to remove primer from cabinet diy.wannabe Painting 3 12-28-2012 10:00 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
how do I remove purple primer from white linoleum floor? amerigoplumbing Flooring 5 04-09-2012 08:22 PM
