-   -   Primer wont stick to semi glossed wainscoting?? best way to remove primer? (http://www.diychatroom.com/f4/primer-wont-stick-semi-glossed-wainscoting-best-way-remove-primer-175616/)
wantboost 03-27-2013 12:23 AM
i made the mistake of not scuffing first.
Previous paint is latex i checked the old cans. I applied primer then 2 days later when i went to paint walls i dripped some paint onto the wainscoting when i went to wipe it with damp cloth all the primer came off on that spot.
So how do i remove all the primer now wood stripper or sand it all down??
thx
joecaption 03-27-2013 12:27 AM
Sand it.
Brushjockey 03-27-2013 07:17 AM
Curious what primer did you use?
jsheridan 03-27-2013 07:22 AM
Key question and piece of info, one would think it would be supplied without asking.
Joe, sand it? Tisk, tisk.
chrisn 03-27-2013 07:55 AM
[QUOTE=jsheridan;1146804]Key question and piece of info, one would think it would be supplied without asking.
Joe, sand it? Tisk, tisk.[/QUOTE]
being disrespectful will get you banned:whistling2:
at least it was not recommended to be torn out:jester:
ToolSeeker 03-27-2013 08:34 AM
If it wipes off with a damp cloth just wipe it off. But the key is still what primer did you use?
wantboost 03-27-2013 08:37 AM
Won't paint stripper be faster??? If I apply waetr to the primer with a srpay bottle its comes off in chunks, I used the behr primer blue label I'll get exact name later...
ToolSeeker 03-27-2013 08:45 AM
I'll assume you have not worked with stripper. No it will be neither quicker or easier. With out starting an argument try another brand of primer such as 123.
wantboost 03-27-2013 08:58 AM
I did the whole room already... Another primer on top of this primer or sand fist??
ToolSeeker 03-27-2013 09:30 AM
If the other primer is not sticking it will need to come off. Primer is your bonding agent if it is wiping off then it is not bonded to the surface. I would wipe off all I could then scuff sand then the other primer. I would check to see if it is just coming off the wainscote or if it's coming off everywhere. Was the wainscote painted before? Are you sure it's not the vinyl coated waincote?
wantboost 03-27-2013 09:45 AM
yes its been painted before. seems to be wood dunno how to check if its vinyl coated.
Should i just sand it or wet it with a spray bottle and use a scraper. when i wet it slightly and and used a power sander it was coming off in chunks. i dunno what the best method would be ....
Brushjockey 03-27-2013 01:32 PM
Might take a little experimentation on your part to see what works best. Don't expect a magic bullet- it's going to take some work.
Try hotish water and a rough scrubbie ( a stripping scrubbie from a paint store/ paint dept is the roughest one I know of)
wantboost 03-27-2013 01:34 PM
Do u mean a sanding sponge?
Brushjockey 03-27-2013 01:53 PM
No-
These-
'http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
jsheridan 03-27-2013 05:24 PM
Should we not recommend that he wait a couple of days to be sure the primer will not bond with the cure, remember, some primers take 4-5 days to fully bond. However, should it not be a bonding primer, it might be harder to remove at that time. This is fine kettle of fish. OP, what primer did you use, specifically, by name. Behr what?
