Which Primer For A Variety Of Situations Drywall, Smoke, Stains - Painting - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 04:09 PM   #1
Which primer for a variety of situations drywall, smoke, stains
We will be closing on a foreclosed home in a few weeks time. I would like to prime all the walls, ceilings, and closets, prior to painting. There are a couple different situations going on. Previous owners were smokers. Not a huge smell, but a little noticeable, so I would like to seal in any smells. Some of the drywall is being patched and 2 ceilings are being redone, (by a drywall contractor) so there will be bare drywall as well here and there. Throughout, there are some stains and a few medium colored walls. I am wondering if there is one primer by Zinnser that would be good all around so i can buy it in 5 gallon buckets. The house size is 1958 sq feet so that will be the next thing to figure out how much paint and primer. Thanks in Advance. Bridget
aussiegirl1590 is offline   Reply With Quote
Old 04-07-2011, 04:36 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I have seen Benjamin Moore Fresh Start do OK on nicotine stains but they were light stains. That was my mom's house and I did it 12 years ago and it is starting to show signs of needing to be done again. If the Ceiling is yellow, I would trust nothing short of Oil Coverstain or even BIN. Basicly any primer is ok on fresh drywall.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-07-2011, 05:09 PM   #3
Rewards Points: 252
Cover Stain or Oil based fresh start will work fine to cover the nicotine stains - however if you want to get rid of the smell as well, the only one that really works is the BIN (which will form a vapor barrier). The downside to BIN is that is has a very strong odor and it is very expensive (@ 40 bucks a gallon). There is a BIN2 product out now which is a cheaper version, but I really havne't seen it around much and haven't tried it yet. For new drywall, patchwork, etc, any latex primer will be fine - you'll hear fresh start and 1-2-3 from Zinsser referenced a lot here. It might pay to pick up some BIN and use that where there is existing drywall that is nicotine stained and smells like smoke, then get some cheaper 1-2-3 or fresh start for where you have new drywall or in rooms that don't have stains and don't smell...
good luck!
mazzonetv is offline   Reply With Quote
Old 04-07-2011, 05:14 PM   #4
Alright, Thanks. We are going back out Sunday and will reassess it then. I see BM has a stain blocking primer as well. I just want to make sure to cover any stains as well as smell and do it right the 1st time.
Old 04-07-2011, 06:03 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
Tricky situation- Bin will do it all, but it dries so quick & it's hard to handle and the strong vapors will knock you out ( use a good respirator-).
My approach might be to do most the priming with Zin 123, and watch for where it bleeds through. Those areas I'd hit again with the bin. That way you get what needs it and save yourself and your wallet. BIN has just about doubled in price in the last month or so- must be the lac bugs are on strike or something...
Brushjockey is offline   Reply With Quote
Old 04-07-2011, 07:01 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
We've always had good luck using Sherwin Williams Pro Block on nicotine and water stains. It can be used on your bare drywall too. It is a stain blocking primer.
housepaintingny is offline   Reply With Quote
Old 04-07-2011, 07:12 PM   #7
House- Not a SW guy- is that oil or H2o? Have a similar situation now and looking for a good alternative to using BIN.
Old 04-07-2011, 07:25 PM   #8
Rewards Points: 616
It is water, but it is all around pretty good stuff. We use it in general whenever an interior primer is needed. Have covered many nicotine stained walls and ceilings with it, with no problems.
Old 04-07-2011, 07:50 PM   #9
Rewards Points: 22
I am painting an entire house (inside) using bin primer. 1 room finished and 2 ready to go soon. the bin does have an odor, open all windows and it is bearable. stay away from drafts as it dries fast (alcohol base). I have a thread from about 2 months ago about painting over soot damage, you may want to read it. I am sure Joe will chime in at some point. his advise on my thread was invaluable. my textured ceiling soaked up a lot, and the walls had great coverage. finish was bm regal (egg shell), 2 coats. best looking room in the house, no soot!!! I bought the bin at a hardware store who is a bm dealer. 10 gals to start, and a great discount.
good luck, bernie
bernie963 is offline   Reply With Quote
Old 04-07-2011, 08:20 PM   #10
Ok, so after reading threads, oil based primer is better than water to block stains. What about to seal in the odors. Will BIN be my only and best option? It is not that strong of a smell, in the house, but it is colder right now. I don't know if the heat and humidity will bring out any smells that have been hidden when we have been there, if you understand what I mean. Also if I use BIN, will we really need respirators when rolling it on? Thanks again
Old 04-07-2011, 08:54 PM   #11
Experienced
Jackofall1's Avatar
You can use Kilz Original (oil based) for both odors and stains, it has a strong odor as all oil primers do, I would use a product like PVA for fresh drywall it is far more cost effective.
Mark
Old 04-07-2011, 10:01 PM   #12
ltd
Rewards Points: 536
ok here we go ,for nicotine stained walls ,over old oil base ,water stained,and basically dingy walls zinsser cover stain is the best. zinsser recommends cover stain over bin for nicitine .it is true that cover stain is not a Oder sealer but in my experience once you prime and paint i never had a problem with cover stain, about 22dollars at the big box .do like the pros do .a 5gal, bucket with a screen ,no need to clean up at end of day just load up roller hang on screen and cover with a towl .at end of job .clean up or pitch. for dry wall i would use a primer sealer , valspar primer sealer ,s/w pro block
ltd is offline   Reply With Quote
Old 06-10-2011, 11:29 AM   #13
I used BIN on my entire house of old wood panelling and had good results. Not very many chipped paint incidents, zero stains coming through and it's been 5 years. I was alittle put off when I first started using it because it does have a very strange "watery" texture. You must keep stirring it as you go as the ingredients will settle to the bottom quickly. The smell is strong, I didn't use a respirator, had the windows cracked, it didn't bother me much at all. Maybe I'll get lung cancer from who knows? I found it a pain in the butt to use because it drips like crazy and makes a mess but it does work. Once you get the hang of it goes pretty well but I would choose a thicker product the next time around.
annie68164 is offline   Reply With Quote
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 01:27 PM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
Primers shellie.elyse Painting 3 10-07-2008 11:00 PM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
