Old 04-05-2012, 05:30 AM   #16
paper hanger and painter
chrisn's Avatar
Primer Type Over Drywall That Previously Had Wallpaper
Originally Posted by Brushjockey View Post
Perma-white..
Be careful getting this tinted. If you are just going white, no problem.
Old 04-05-2012, 05:32 AM   #17
chrisn's Avatar
Ahhh, I see!
Be careful if you try and tint this stuff a different color.
Old 04-12-2012, 02:35 PM   #18
The Gardz Problem Surface Sealer is now on all walls and the small ceiling portion I repaired.
The Benjamin Moore Ben color for the walls is lily lavender. There are some pencil lines and wood trim stains on the drywall from before it was originally wall papered.
Will 2 coats of the Ben be sufficient to hide the pencil lines and wood trim stains, or should I first place another (white?) primer on top of the Gardz?
jdbs3 is offline   Reply With Quote
Old 04-12-2012, 05:25 PM   #19
chrisn's Avatar
Yes, depending on the type of stain, not sure what you mean by wood trim stain
Old 04-13-2012, 08:15 AM   #20
... not sure what you mean by wood trim stain
There are 2 windows in the room. The wood trim was stained with a brown stain when the house was built. Knowing they were going to wallpaper, the stainers were not careful. Thus the stain on the drywall around the preimeter of the windows found after I removed the wallpaper.
I've decided to be conservative and put an oil based primer over these stains just to be on the safe side.
Thanks again for all the input.
Old 04-13-2012, 05:52 PM   #21
chrisn's Avatar
cannot go wrong with that idea
Old 04-13-2012, 06:11 PM   #22
Mr. Paint's Avatar
sdester: I enjoy reading your comments, but "Chimp change?" Thats what Cheetah used. I'll consider it a typo, 'cause I know you meant, chump change.
Mr. Paint is offline   Reply With Quote
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 01:27 PM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 03:31 AM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 06:41 PM
