Primer, Then Added Texture, Primer Again? - Painting - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 11:05 PM   #1
primer, then added texture, primer again?
I put primer on new sheet rock then they ended up doing a light texture on the walls. Do i need to primer again or can I just paint it?
volivier68 is offline   Reply With Quote
Old 04-22-2011, 10:32 AM   #2
Gymschu's Avatar
Rewards Points: 236
I always feel it is best to prime again. The primer will soak into the texture and give you a solid surface for topcoating. If you don't prime, you will end up with blotchy areas and dead spots as the paint soaks into the texture unevenly.
Old 04-22-2011, 10:46 AM   #3
I was afraid of that, hate to do the work, but want it to look good.
Old 04-22-2011, 10:50 AM   #4
the Musigician
DangerMouse's Avatar
I've painted straight over texture and years later it still looks fine, but maybe I just got lucky?
DM
Old 04-22-2011, 11:28 AM   #5
A Little Of Everything
Rewards Points: 1,362
Is the light texture a drywall mud mixture that was sprayed on?
DrHicks is online now   Reply With Quote
Old 04-22-2011, 04:43 PM   #6
Too Short? Cut it Again!
Come on, once you are in the mood, how long will putting a nice primer and base for everything else on top take you? And how often are you going to have to suffer this extraordinary pain?
Prime everything again. Then apply two coats of nice finish. Tint the primer if applying a dark color. Then let the kids, dogs, cats, wife and all back in and not worry about it for years or until you tire of the color.
Old 04-22-2011, 06:24 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
This. If it was I would prime. If it was just sand added to paint then you can just paint right over it.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
DrHicks (04-22-2011)
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
Best primer over orange peel texture? GFW Painting 2 12-04-2008 05:24 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
