Primer / Sealer Question For New Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 11-27-2013, 05:18 PM   #1
Rewards Points: 117
Primer / Sealer question for new drywall
Getting ready to paint in my basement soon. We used 1/2" mold resistant purple board through out. (some green board under the stairs too)
I am getting mixed opinions on what I should start out with... a drywall sealer or just a primer. Any help is appreciated.
tommyxv is offline   Reply With Quote
Old 11-27-2013, 05:33 PM   #2
DIY staff
Rewards Points: 7,174
I moved this to 'painting' for you---
I'll leave this for a painter to answer---I believe I would use a good primer rather than PVA---but listen to the painters----Mike----
Old 11-27-2013, 05:46 PM   #3
Rewards Points: 117
Sry about that. Thanks.
Old 11-27-2013, 06:34 PM   #4
Rewards Points: 13,274
Zinsser 123 is all you'll need.
Looks like you still have a lot of sanding to do. Once you prime you'll see it. Fix and prime again before moving on to painting two coats.
(Screw patches are not hazy enough, tape lines are not mudded out wide enough.)
If you can feel it with your hand it's going to show.
Could have saved a whole lot of money skipping the green and purple board. It's only moisture resistant on the front side not the back side.
princelake (11-27-2013)
Old 11-27-2013, 06:52 PM   #5
747
registered
747's Avatar
Rewards Points: 534
yep bulleyes 123 primer sealer
747 is offline   Reply With Quote
Old 11-27-2013, 07:20 PM   #6
Rewards Points: 117
Thanks for the info. That pic is not the finished drywall. (I noted that under the pic). I just didn't have a more recent photo yet. All the joints are feather out properly and sanded now.
I will check out that stuff. Latex based?? Thanks
Old 11-27-2013, 07:28 PM   #7
DIY staff
Yes,latex based----good stuff---have it shaken when you buy it---or be sure to stir well before use.
Old 11-27-2013, 07:58 PM   #8
Rewards Points: 117
Thanks again.
The Following User Says Thank You to tommyxv For This Useful Post:
oh'mike (11-27-2013)
Old 11-27-2013, 10:07 PM   #9
Rewards Points: 512
ya any of that green board, blue board, purple board,etc. is a joke. i've pulled out lots of board with mold on it after floods. not worth the extra money.
Different companies make new drywall primer.
princelake is offline   Reply With Quote
Old 11-28-2013, 06:17 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Although 123 will work just fine, this MIGHT save you some $$
Old 11-28-2013, 07:43 AM   #11
Rewards Points: 5,974
That board is not WATERPROOF it is only moisture resistant. That is why it is approved for moist areas but not wet areas. You can use it in bathrooms but not in showers.
Old 11-28-2013, 09:35 AM   #12
Rewards Points: 117
I bought it because I like purple and green.
For real though, it was on sale and cheaper than regular rock at the time, plus I had some discounts applied. I bought 80 sheets of 1/2" on the first order at a $9.80 a sheet. The bottom side of the soffit we used 1/4" to save a little bit more of head room.
Thanks, Ill check that out too.
Old 11-28-2013, 09:42 AM   #13
That was a mistake. Should have been at a minimum 1/2 light weight or your going to get sagging and screw pops.
Old 11-28-2013, 10:16 AM   #14
Gymschu's Avatar
Rewards Points: 476
That's gonna be nice when it is completed.
The Following User Says Thank You to Gymschu For This Useful Post:
oh'mike (11-28-2013)
Old 11-28-2013, 11:52 AM   #15
Rewards Points: 117
I do not think it will sag. There is a center support. Everything is screwed and glued with PL 400. The butt joint has a nailer also. (not pictured)
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
Redoing oak kitchen cabinets- primer question Mroe192 Painting 7 02-27-2013 11:20 PM
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 01:27 PM
Zinsser BIN Primer Sealer watery? caroln242 Painting 4 10-11-2011 08:58 PM
Which primer for a variety of situations drywall, smoke, stains aussiegirl1590 Painting 12 06-10-2011 11:29 AM
