Old 12-09-2012, 07:44 PM   #1
Primer or Sealer?
I am repairing the fascia and soffitt on both my dormers but would like to hold off painting/staining until I complete my new porch addition, which will run underneath the dormers, and do it all at the same time...the porch won't be completed until July/Aug...would a primer last this long without painting/staining or should I use something else? A friend suggested I should use a sealer but I would like an expert opinion.
Thank you
Ridgerunner is offline   Reply With Quote
Old 12-09-2012, 08:46 PM   #2
Matthewt1970's Avatar
Primer or Sealer?
What surface are u dealing with? Is any of it already painted?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 12-09-2012, 08:56 PM   #3
Primer or Sealer?
Sorry should have posted that...it is all raw wood...the 1x8 fascia is syp and right now I have it in my house since we are having storms and getting ready to freeze for a week then back up to 60s and sunny! Plan to use the primer/sealer on all 6 sides before installing.
Old 12-09-2012, 09:05 PM   #4
Primer or Sealer?
Backpriming is an effort in futility. Wood will always rot on the weather side. If it were me I would use and oil primer and then 2 latex topcoats.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Ridgerunner (12-09-2012)
Old 12-09-2012, 09:14 PM   #5
Primer or Sealer?
Thanks! I'll head to the stores tomorrow! I think I can get the BM Fresh Start here and we also have a Sherwin-Williams store here. Would one be better than the other?
Old 12-09-2012, 09:30 PM   #6
Primer or Sealer?
By prmiing and painting all sides it will really help to stop the wood from cupping and seal up the ends where it's going to be soaking up most of the water.
Great way to go.
Old 12-09-2012, 09:39 PM   #7
Primer or Sealer?
BM and SW are both good primers
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 12-09-2012, 09:57 PM   #8
Primer or Sealer?
Thanks for your prompt replies! After Priming, will I need to paint them now or can I wait till I complete the porch? Guess I could paint them before installing also...Not a really big deal I just haven't decided on color yet and wanted the porch trim to match..
Old 12-09-2012, 10:09 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
Primer or Sealer?
Some say it is best to paint over primer before it completely cures ( gets to its hardest point) about 30 days or so.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 12-09-2012, 10:17 PM   #10
Primer or Sealer?
Guess I'd best be makin up my mind then on the paint!!
Thanks all for your input it's really appreciated!
Primer / Sealer For New Drywall...Which Of My 3 Choices Is Best? Dreams Painting 23 02-10-2012 03:22 PM
Zinsser BIN Primer Sealer watery? caroln242 Painting 4 10-11-2011 08:58 PM
using BIN Shellac Base Primer Sealer joefromcal Painting 10 05-04-2009 06:47 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Primer Sealer Oil or Water Based? petey Painting 7 05-11-2008 07:11 AM
