Which Primer/sealer? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 05:22 PM   #16
Rewards Points: 4,796
Originally Posted by chrisn View Post
First off, 1 coat primer and 2 finish coats is still the industry standard( at least in my world)
Of course it is. It doesn't mean it's cheaper to use primer (as you tried to claim) nor does it mean it's always necessary.
You will hear no more from me
That sounds good.
obviously you are way smarter than I
Probably, but what's your IQ? Then we can know for sure, if that's the sort of thing that's important to you. To me what's important is getting out the right information.
jeffnc is offline   Reply With Quote
Old 07-26-2012, 06:11 PM   #17
Too Short? Cut it Again!
Welcome to the forum. It is so nice to have you.
Old 07-26-2012, 07:55 PM   #18
Thanks sd.
Old 07-26-2012, 10:37 PM   #19
Rewards Points: 506
Funny thing...
I (acting as the OP) didn't ask IF I should use a separate primer/sealer...I asked WHICH primer/sealer would best fit the described scenario. So, all the arguments for the paints which don't require a separate primer turn out to not be the right information, because it didn't address the original question.
jlmran is offline   Reply With Quote
Old 07-27-2012, 03:44 AM   #20
Originally Posted by jlmran View Post
Funny thing...
Actually it did. You asked several questions, including if you should prime once or twice. After priming your walls due to wallpaper glue, you do not necessarily need to prime over the joint compound you patch with, depending on the type of paint used, etc.
Old 07-27-2012, 04:27 AM   #21
paper hanger and painter
chrisn's Avatar
Rewards Points: 466
subtle, very subtle
chrisn is online now   Reply With Quote
Can I use exterior primer/sealer on new drywall? silli_kitti Painting 6 07-07-2010 10:53 AM
