Primer Raises Grain On Drywall Paper - Painting - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 08:08 PM   #1
Rewards Points: 288
Primer Raises Grain on Drywall Paper
It's been eons since I have painted on new sheetrock.
Advice ?
I was priming some exposed cast iron DWV pipe. Using BIN Red Can Shellac based primer.
While I had the brush wet with paint...I decided to prime a new wall - 2'x3' area as I wanted to paint some test paint swatches on it.
On the areas where there was mud, the primer dried well and smooth.
On the paper, it raised the grain quite much.
Now I know I should be sanding after applying primer..
It's been awhile since I have painted on new rock.
Does primer generally raise the grain on the paper that much & or is it because I was using shellac based primer.
mobiledynamics is offline   Reply With Quote
Old 04-22-2012, 08:51 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Shellac and oil will do that , a waterbased primer usually will not.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (04-22-2012)
Old 04-23-2012, 05:07 AM   #3
Was it raised grain, or furries from oversanding that were hardened by the primer? BIN is spec'd for new drywall. We did a job yeeeaaaars ago for a professor who hired his students to sand all the new drywall, and then apply oil based primer. They sanded the heck out of it and then the oil locked down all the furred paper, the final felt and looked like eighty weight paper. What a mess. We had to sand all the walls with a palm sander and heavy paper. In his effort to save a few bucks, he ended up costing himself much more than had he not, and the final job was inferior to boot.
Old 04-23-2012, 07:07 AM   #4
Rewards Points: 288
I considered that....as it was the feathered edge of JC to the paper. But I don't think it was furred paper. Just found it interested. It's clear as day. Primer leveled even with a cheap a@# chip brush and is nice and smooth on the mud. Just how it extends into the paper, it's all raised and grainy. And yes, it's quite pronounced. I was planing to take 100 and knock it down.
Primer choice on New Drywall zhtway Painting 11 07-04-2012 04:34 PM
Drywall Primer cougar01 Painting 10 04-06-2012 06:48 PM
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 12:27 PM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 02:31 AM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 04:37 PM
