Primer Questions - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2008, 10:32 PM   #1
Primer questions
I am trying to paint over dark wallpaper with a raised design.
I primed the walls. How many coats does it need?
If more than one, how long do I wait?
dlefk is offline   Reply With Quote
Old 10-05-2008, 04:29 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 618
What primer did you use? Normally one coat is enough. And curse you for painting over the paper in the first place
chrisn is online now   Reply With Quote
Old 10-05-2008, 08:56 AM   #3
Thank you Chris
It is Zinsser Bulls eye Odorless
The wallpaper was brown and purple and gold! What was your beef with painting over the wallpaper?
Old 10-05-2008, 11:39 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Painting over wallpaper is bad because,
a) it looks bad.
b) it often fails, leaving you with a mess you have to remove anyway.
As for the primer. Zinsser Odorless has one of the worse hides of any oil based stain blocker I've ever seen. I was surprise to note this considering all the other Zinsser products I've used have good hide to them.
poppameth is offline   Reply With Quote
Old 10-05-2008, 02:42 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Yep, all the things that make a paint/primer stink are what make them good, for the most part. You should probably be OK inside with that stuff but on any bare wood, inside or out, go with the full strength stuff. If the oderless was just as strong as the stinky stuff, then there wouldn't be the stinky stuff.
Old 10-06-2008, 06:02 AM   #6
chrisn's Avatar
Rewards Points: 618
It's just wrong. Anybody that works in the industry( and gets paid) will tell you the same thing. It is almost always better to work with the original wall.
Old 10-06-2008, 09:43 PM   #7
Rewards Points: 2,906
The problem is that eventually the paste holding the wall paper on will begin to fail, and the result will be that the wallpaper will, very slowly, start to peel at the seams.
Wallpaper is a chore to remove at the best of times. Painting over it just makes it more of a chore. The layers of paint on the wallpaper impede the penetration of moisture through to the paste layer to re-emulsify it.
It's better to remove wallpaper before painting, and the reason isn't just "because". It's because painting over it just creates a chore that will be more difficult to do in the future.
Nestor_Kelebay is offline   Reply With Quote
Old 10-07-2008, 04:29 AM   #8
chrisn's Avatar
Rewards Points: 618
There you go!
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 04:32 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 07:00 AM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 06:38 AM
