Is Primer Over Paint Less Effective Than Primer First When Dealing With Stains? - Painting - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 08:50 AM   #1
Rewards Points: 296
Is primer over paint less effective than primer first when dealing with stains?
I got into a discussion with a friend recently. He had a brown water mark stain on the ceiling and wanted to paint over it. He initially put white paint on it and then when that did not work too well, he put two coats of primer and then more white paint but he still does not like the way it looks. He says it is a bit too grayish in color.
So my question would be: Is primer much more effective if you put it directly on a stain (so that is can chemically bond or otherwise alter the stain) or does it make no difference?
Eagle One is offline   Reply With Quote
Old 02-10-2012, 08:55 AM   #2
Rewards Points: 13,300
It still should have covered.
Could be the stain is still wet, insulation above it is holding in moisture and should have been replaced, old paint or not stured enough ect.
Old 02-10-2012, 10:49 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
What primer was used? Not all primers are stain killers. The best for that is BIN- an alcohol based pigmented shellac.
Most water based stain killers will need 2 coats with a fair dry between.
It does not matter if the primer is on the stain, or on a paint that let the stain bleed through.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
BraniksPainting (02-10-2012)
Old 02-10-2012, 01:02 PM   #4
Too Short? Cut it Again!
Shouldn't make a difference but as mentioned, if you have not addressed what is causing the staining, the layer of paint just provides another layer for the stain to seep into. The closer you can apply a sealer/stainblocker to the source the better. But the paint is on so you move forward.
Not sure why you are getting graying unless you are racing the recoat and cure times of the materials?
Old 02-10-2012, 02:58 PM   #5
Rewards Points: 296
My friend used two coats of Kilz Stain blocker/sealer primer. That is a pretty good brand from what I understand. He resolved the leakage issue above the ceiling already so the moisture is not continuing and the insulation was removed. The spot still looks slightly gray to him, like a shadow a bit as though the priming and painting did not work so well to cover it up completely. He is probably just obsessed with it more than others and an unknowning person probably could not tell it was there.
I have a few of these stains myself so I need to figure out what works best to beat these brown water stains. I will keep the BIN primer in mind when it is time to work on that. Thanks for all the replies.
Old 02-10-2012, 03:18 PM   #6
Mr. Paint's Avatar
Primers are engineered to perform different functions. There are bonding primers, hiding primers and sealing primers. If you are dealing with a water-extractive stain, you need to be sure the source of the water is repaired and that the surface is dry. Water-based primers can re-activate the stain and may allow it to bleed into the finish.
An oil-based, fast-dry primer, such as Cover Stain, is made for this situation.
Mr. Paint is offline   Reply With Quote
Old 02-10-2012, 05:32 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
Only the original oil base is any good
Bin is what you need
Old 02-10-2012, 11:19 PM   #8
BraniksPainting's Avatar
I agree with BrushJockey......BIN alcohol based primer is best.
BraniksPainting is offline   Reply With Quote
Old 02-10-2012, 11:30 PM   #9
I hate to show my possible age. 23.
This is the the way it still works, expressed yet again.
Sealer
Primer
Underlay
2- Coats Finish
This is the gospel taught me by geezers with something close to Jesus Fans. You start combining too many of these things into one product? Child you be playing with the Devil.
Anybody reading this noticing the new HD ads. They seem to be dumping BEHRly paint. They are pushing Glidden now and they are tweaking the language about primer and paint in one. They are suggesting only you might be able to skip a primer coat. Clever.
Total BS of course but they seem to be bailing on BEHRly as their go to product.
Old 02-13-2012, 11:12 AM   #10
Rewards Points: 296
Good question about the primer/paint all in ones that are now out there. Anybody have any good experiences with these products? Heck, if you can get away with just one coat, what a time saver that would be! Sounds too good to be true, eh?
Old 02-13-2012, 06:08 PM   #11
chrisn's Avatar
Rewards Points: 232
that's because it is
Old 02-13-2012, 08:18 PM   #12
jschaben
Rewards Points: 502
I don't think the primer in paint people say much about one coat.... just imply it. Did a project with the stuff last week and it took 4 coats and some touch up. Behr of course. It seemed to work ok on my house several months ago but I think it was since I was spraying, I was able to go back over it several times thinking I just missed a spot. I brushed this project so it was more evident.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 02-14-2012, 04:26 AM   #13
chrisn's Avatar
Rewards Points: 232
now there is a surprise
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-10-2011 12:45 AM
Drywall primer or paint and liquid nails rboutin2 Drywall & Plaster 13 10-04-2011 05:04 AM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 10:06 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
