Old 06-11-2012, 11:37 AM   #1
Primer over oil base poly
I received some bad advise. After priming and painting hardwood floors, I was told to seal it with an oil based floor poly. But it left my white paint yellow. Can I put zinsser 123 primer over the ploy?
Kathybmcd is offline   Reply With Quote
Old 06-11-2012, 03:23 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Oh, you did get some bad advice. And now have a problem.
Whatever you do use to prime it- the poly needs to be sanded well to get a physical bond. 123 isn't a good choice for floors.
I'm going to hold off and see if someone ( ric to the rescue!) has a gooder primer idea than what I'm thinking of...
(BTW- if you used a floor enamel- no top coat needed. )
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-11-2012, 07:48 PM   #3
Matthewt1970's Avatar
what did you use to prime and paint with?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-11-2012, 09:26 PM   #4
Gymschu's Avatar
In the history of bad ideas, I'm sorry to say that painting hardwood floors is in the top 5.
Please help! I'm repainting bedroom furniture and primer is "gunking"! Fun2Learn Painting 12 02-13-2012 07:54 AM
Latex Primer over Oil Base Paint on ceiling LynniieRockz Painting 15 11-12-2011 05:14 PM
oil base primer lwoods Painting 1 09-20-2011 07:00 PM
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 15 03-24-2011 11:20 AM
can i put water based poly over oil base? mayhem69 Flooring 8 02-01-2010 06:54 AM
