-   -   Primer over oil base poly (http://www.diychatroom.com/f4/primer-over-oil-base-poly-146709/)
Kathybmcd 06-11-2012 10:37 AM
I received some bad advise. After priming and painting hardwood floors, I was told to seal it with an oil based floor poly. But it left my white paint yellow. Can I put zinsser 123 primer over the ploy?
Brushjockey 06-11-2012 02:23 PM
Oh, you did get some bad advice. And now have a problem.
Whatever you do use to prime it- the poly needs to be sanded well to get a physical bond. 123 isn't a good choice for floors.
I'm going to hold off and see if someone ( ric to the rescue!) has a gooder primer idea than what I'm thinking of...
(BTW- if you used a floor enamel- no top coat needed. )
Matthewt1970 06-11-2012 06:48 PM
what did you use to prime and paint with?
Gymschu 06-11-2012 08:26 PM
In the history of bad ideas, I'm sorry to say that painting hardwood floors is in the top 5.
