Primer Over Backing Of Wallpaper. Please Help!! - Painting - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 01:23 AM   #1
primer over backing of wallpaper. please help!!
hello,
I hired a paint contractor to remove wallpaper and paint. He primed over the backing of the wallpaper. He's not painting the room yet. I can see the texture different in the wall. bumpy, because of the glue underneath and also the backing paper. My texture is tiny. His mistake made the wall look funny in several part of the room. how can I fix his mistakes I'll paint the room. he's not coming back. took 50% deposit money and run.
Any suggestions would be very much appreciated.
Thank you very much.
beginner1234567 is offline   Reply With Quote
Old 02-08-2011, 09:57 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
So he just basicly ripped the face of the wallpaper off and then primed it? If he primed it with oil then you can just skim coat it with joint compond, sand, prime again and paint. If not then you really need to prime it with oil to block any moisture from joint compond and paint from reactivating the wallpaper glue and causing it to bubble.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
beginner1234567 (02-08-2011)
Old 02-08-2011, 11:00 AM   #3
Originally Posted by Matthewt1970 View Post
So he just basicly ripped the face of the wallpaper off and then primed it?.
yes, He ripped the wallpaper off but leave some of the backing paper and glue underneath and then primed it.
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 05:03 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
