Primer For Old Dry Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 07-07-2014, 07:20 PM   #1
cj133's Avatar
Rewards Points: 308
Primer for old dry paint?
So, I got the Kilz original on the plaster walls and am extremely happy with the results. In fact, I'm completely amazed at how well that stuff seems to stick to things including me.
However, I still need to prime the wood trim which has a very chalky dry once was white paint on it. I didn't use the Kilz because I was concentrating on the walls and ceiling, now I kind of wonder if that was a dumb move.
Do I even need a primer if the paint seems reasonably solid and not dusty / powdery? It's just very dry feeling and I have no idea how old it is, could be 40+ years old judging by the wallpaper we took down. If I had to guess, I don't see any reason paint wouldn't bond to it extremely well but I don't want to do something stupid if I can avoid it.
I cannot find Zinsser Gardz anywhere locally so if possible, would prefer to find an alternative.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 07-07-2014, 07:26 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
It would be safer to use a bonding primer. The Kilz will work.....kind of. It sticks pretty well just by virtue of being oil base, but its not really a bonding primer.
It being a dull, flat paint your going over helps, but as old as it is its almost certainly oil base. And latex paint over oil doesn't usually bond well.
Jmayspaint is offline   Reply With Quote
Old 07-07-2014, 07:38 PM   #3
cj133's Avatar
Rewards Points: 308
Is there a good bonding primer you can recommend for this application?
Old 07-07-2014, 08:36 PM   #4
Gymschu's Avatar
Rewards Points: 230
Zinsser 1-2-3 is your best friend in this situation:
The Following User Says Thank You to Gymschu For This Useful Post:
Jmayspaint (07-07-2014)
Old 07-08-2014, 02:18 PM   #5
cj133's Avatar
Rewards Points: 308
I've heard a lot of good things about this primer.
Is it also good for joint compound / drywall, or just painted surfaces like I am dealing with?
Not sure if others will see this question but, I read something regarding sanding semi-gloss paint before painting. While this is a completely different topic, I'm using satin latex on my walls and ceiling and semi-gloss latex on trim (I hate flat paint). Will I need to sand to take some of the sheen off before painting in the future?
Old 07-08-2014, 06:18 PM   #6
Gymschu's Avatar
Rewards Points: 230
Yes, you need to scuff sand a semi-gloss surface before painting. Wipe off the dust before applying any paint.
cj133 (07-08-2014)
How paint primer actually works? konsole Painting 4 11-11-2010 05:48 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
