Oil-Base Primer-Sealer
Stain Killer Bond Coat
* Interior and exterior
* Blocks cedar & redwood bleed
* Use for fire, smoke & water damage
* Sticks to all surfaces without sanding
* Fast drying - recoat in 2 hours
High Hide Cover Stain is a high-performance, all-surface oil-base primer-sealer that offers outstanding adhesion and stain killing power and dries to recoat in 2 hours.
High Hide Cover Stain may be tinted toward the color of the finish coat to help the topcoat hide in one coat.
High Hide Cover Stain offers excellent flexibility and penetration making it ideal for exterior application to wood siding and trim. It seals surfaces with one coat offering excellent hold-out for enamels of any sheen.
Use High Hide Cover Stain for interior and exterior walls, ceilings, doors, trim, paneling, siding, window frames and shutters - any surface where a high-hiding, high-adhesion primer is desired. This all-surface low-VOC primer-sealer can be used over or under any oil or latex architectural paint and is ideal for water damage, fire damage and smoke damaged (including nicotine) surfaces.
Meets stringent SCAQMD Air Quality Standards for Specialty Primers, Sealers and Undercoaters.
