Primer & Joint Compound - Painting - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 10:29 AM   #1
I applied primer to the walls/ceiling yesterday and found some spots that still needs work done to it. How long must I wait for the primer (latex) to dry/cure before applying more joint compound on top? Are there any precautions I need to know of ahead of time?
Always Somethin is offline   Reply With Quote
Old 04-27-2012, 10:33 AM   #2
Rewards Points: 12,876
Depends on the paint, some dry faster then others and it also depends on the temp. and humity.
Wait a day and you would be safe.
Any touch ups will need to be lightly sanded with a sanding sponge and primed again.
Old 04-27-2012, 11:49 AM   #3
Wow! Thanks for replying so fast.
A couple of spots need to be smoothed over better, but there is 1 spot that I skim coated with joint compound and fogot all about until after I primered. That needs all sanded back down and redone.
Old 04-27-2012, 03:39 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Most primers dry really fast- I put a fan on it and can do something in an hour.
But just to be safe- what was the primer?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Does all purpose joint compound stick to semigloss ceiling paint in kitchen or bathroom? ziki Kitchen & Bath Remodeling 2 07-24-2010 12:13 PM
Joint Compound shaggy0125 Painting 8 01-12-2010 03:55 AM
defective joint compound newbpainter General DIY Discussions 8 05-24-2009 10:52 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
