Primer Included In Paint... Does It Work - Painting - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 12:36 PM   #1
primer included in paint... does it work
I have a house which has an oil based paint that is 20 years old but in relatively good shape. Do I need to put on a separate primer coat (then main coat) or are the new paints that include the primer going to be just as good for long term durability.
don50
don50 is offline   Reply With Quote
Old 09-11-2011, 01:09 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Of course it doesn't work. It's nothing but a marketing ploy. You try and combine a paint and a primer in one product, all you get is a product that is neither a good primer nor a good paint.
In your case you want to wash the walls down and prime with ideally an oil based primer like Zinsser Coverstain. Barring that you can use a high quality acrylic like Zinsser 1-2-3. Zinsser also has a couple new high adhesion primers called Bondz and Ultra Prime if I recall correctly. Either route, you can top coat with whatever you want, preferably not paint from any of the big box stores.
Darkling Designs
poppameth is offline   Reply With Quote
Old 09-11-2011, 01:22 PM   #3
JohnKC's Avatar
Then why are industry-leading and respected companies like Benjamin Moore and Sherwin Williams advertising their top-of-line products as self-priming and as having the primer and paint in the same can?
There is such a thing as "progress" you know. At one time, it was said that "all-weather" tires were just a marketing ploy - that you had to have "snow" tires on during winter weather, and regular tires for the other seasons. Don't imagine that many of us still have that stack of snow tires sitting in our garage ready to go on at the hint of snow season.
And before you say, "no they don't" concerning the "respected" brands,
JohnKC is offline   Reply With Quote
Old 09-11-2011, 02:20 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
John- we've done this before
THE question is, what do you want your primer- primer in paint to do ?
IF you can answer that well, then we can answer the question.
I carry about 5 primers- they all do different things. ANYBODYS supposed all in one will not stop stains, adhere well to glossy surfaces, etc.
Primers are not one thing, they are many different things.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-11-2011, 05:31 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
[quote=JohnKC;725946]Then why are industry-leading and respected companies like Benjamin Moore and Sherwin Williams advertising their top-of-line products as self-priming and as having the primer and paint in the same can?
[/quote]
It is still a marketing ploy and nothing more. Respectable or not.
Old 09-11-2011, 05:53 PM   #6
ltd
Rewards Points: 536
john yes you can use it in some applactions as a primer .but try and use it over 25 year old gloss alkyd, it will not adhere at least not to my likeing . or use it over warter staind walls ,nictine stained walls. guess what it wont work. yea but the poster says its paint and primer in one.so now you have all the labor in doing this and the paint dont stick ,warter spots come through ,and the nicckatine comes through. and heres what gets me and i might be wrong on this one ,people think you put one coat on and you painted and primed in that one coat .no first coat is primer and 2 coat is top coat
ltd is offline   Reply With Quote
Old 09-11-2011, 06:49 PM   #7
Gymschu's Avatar
Rewards Points: 460
No professional in his right mind would use the paint and primer in one process no matter how much progress it represents. 'nuff said, end of story.
Gymschu is online now   Reply With Quote
Old 09-11-2011, 08:26 PM   #8
Gym- that is a bit of an overstatement. I do know of good contractors ( right from sister forum Paint Talk) that swear by 2 coats Aura over bare sheetrock.
But bare sheetrock isn't the only situation one can encounter painting that might need a primer.
Old 09-12-2011, 03:21 AM   #9
chrisn's Avatar
Rewards Points: 224
Ya, and as you pointed out( I think) why use $60 paint as you're first coat? Makes no sense to me, but ,hey, to each there own.
Old 09-12-2011, 06:41 AM   #10
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yep it's still just marketing. Read the back of the can before commenting on these reputable companies' marketing tactics. There are generally one or two substrates listed that it can self prime on. Everything else will have a primer recommendation first.
Darkling Designs
The Following User Says Thank You to poppameth For This Useful Post:
ltd (09-12-2011)
Old 09-12-2011, 09:16 PM   #11
don50
Thanks for the great info..... any thoughts as to what is the best primer and preparation for an oil based paint that is probably 20 years old. I bought the house 8 years ago and the surface is surprisingly still in relatively good shape.
Don50
Old 09-13-2011, 02:35 AM   #12
chrisn's Avatar
Rewards Points: 224
Don50
here you go
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 01:25 PM
Stucco over paint, will Primer work ? iMisspell Building & Construction 5 05-14-2009 05:07 PM
