Primer Guestion - Painting - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 10:45 PM   #1
primer guestion
Do I have to prime new wood on outside porch
kaykaykitch is offline   Reply With Quote
Old 08-18-2012, 10:48 PM   #2
Rewards Points: 13,300
Bare wood anyplace that's going to get painted always gets primed.
ltd (08-18-2012)
Old 08-18-2012, 11:00 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Yes- and a slow penetrating oil is best- ask at a real paint store
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-18-2012, 11:00 PM   #4
Rewards Points: 582
yep it sure does....
Old 08-18-2012, 11:58 PM   #5
Paint Pro
no. you can use one coat of behr paint/primer in one.
Expert Paint is offline   Reply With Quote
Old 08-19-2012, 06:12 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
Originally Posted by Expert Paint View Post
no. you can use one acot of behr paint/primer in one.
really, not in my world
Old 08-19-2012, 06:31 AM   #7
Too Short? Cut it Again!
If the new wood is part of a porch floor you plan to paint you should think about sealing or treating it but do not use a primer. Primers are just not built to walk on. And Porch, Floor and Patio Paints are self-priming (not primer and paint in one though). In fact, most specifically recommend you not use a primer under them.
A sealer of 50 percent solvents and 50 percent processed (not raw) lindseed oil is as good as any. Let the solvents evaporate and then follow with either Benjamin Moore Oil Based or Water Based Porch, Floor and Patio Paint. The oil based is urethane reinforced and the waterbased is epoxy reinforced. The oil based is slightly glossier which can make it more slippery when wet.
Old 08-19-2012, 07:45 AM   #8
I've watched my neighbor paint the same window frames 3 times with the miracle PnP in one, and every year it peels off. The first time he asked me what to do-
But nobody wants to do that work.
"If you don't have time to do it right the first time, when do you think you will have time to re do it?
Old 08-19-2012, 07:53 AM   #9
I think he jests with us! I hope so.
The Following User Says Thank You to user1007 For This Useful Post:
ltd (08-19-2012)
Old 08-19-2012, 12:04 PM   #10
Matthewt1970's Avatar
Rewards Points: 1,098
Ya, I hope you were kidding about that.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 08-19-2012, 03:25 PM   #11
Paint Pro
guys. surely i jest. im nearing 80 posts of purely sound advice. . . im entitled to answer a question like that with sarcasm from time to time.
Old 08-19-2012, 03:30 PM   #12
Thanks. It was hard to tell. GIVE US A SIGN!!
Old 08-19-2012, 03:48 PM   #13
Paint Pro
will do next time
Old 08-19-2012, 05:46 PM   #14
chrisn's Avatar
Rewards Points: 232
I sure could not tell
Old 08-19-2012, 11:34 PM   #15
Rewards Points: 256
im going to ask a question here as not to start a new thread hope you dont mind .
whats the correct procedure on staining rough sewn ceder . i want to remove the pine around my windows cause its old and pealing and want to install rough cedar and stain it . when you stain do you need to use some kind of primer first aswell ? also should the entire piece of wood be stained back and front ?
oldrivers is offline   Reply With Quote
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 12:48 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 07:29 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
