-   -   primer guestion (http://www.diychatroom.com/f4/primer-guestion-154142/)
kaykaykitch 08-18-2012 10:45 PM
primer guestion
Do I have to prime new wood on outside porch
joecaption 08-18-2012 10:48 PM
Bare wood anyplace that's going to get painted always gets primed.
Brushjockey 08-18-2012 11:00 PM
Yes- and a slow penetrating oil is best- ask at a real paint store
ben's plumbing 08-18-2012 11:00 PM
yep it sure does....:yes:
Expert Paint 08-18-2012 11:58 PM
no. you can use one coat of behr paint/primer in one.
chrisn 08-19-2012 06:12 AM
Originally Posted by Expert Paint (Post 991914)
no. you can use one acot of behr paint/primer in one.
really,:eek: not in my world:no:
user1007 08-19-2012 06:31 AM
If the new wood is part of a porch floor you plan to paint you should think about sealing or treating it but do not use a primer. Primers are just not built to walk on. And Porch, Floor and Patio Paints are self-priming (not primer and paint in one though). In fact, most specifically recommend you not use a primer under them.
A sealer of 50 percent solvents and 50 percent processed (not raw) lindseed oil is as good as any. Let the solvents evaporate and then follow with either Benjamin Moore Oil Based or Water Based Porch, Floor and Patio Paint. The oil based is urethane reinforced and the waterbased is epoxy reinforced. The oil based is slightly glossier which can make it more slippery when wet.
Brushjockey 08-19-2012 07:45 AM
I've watched my neighbor paint the same window frames 3 times with the miracle PnP in one, and every year it peels off. The first time he asked me what to do-
But nobody wants to do that work.
"If you don't have time to do it right the first time, when do you think you will have time to re do it?
user1007 08-19-2012 07:53 AM
I think he jests with us! I hope so. :laughing:
Matthewt1970 08-19-2012 12:04 PM
Ya, I hope you were kidding about that.
Expert Paint 08-19-2012 03:25 PM
guys. surely i jest. im nearing 80 posts of purely sound advice. . . im entitled to answer a question like that with sarcasm from time to time.
Brushjockey 08-19-2012 03:30 PM
Thanks. It was hard to tell. GIVE US A SIGN!! :laughing::thumbsup:
Expert Paint 08-19-2012 03:48 PM
will do next time
chrisn 08-19-2012 05:46 PM
I sure could not tell:thumbsup:
oldrivers 08-19-2012 11:34 PM
im going to ask a question here as not to start a new thread hope you dont mind .
whats the correct procedure on staining rough sewn ceder . i want to remove the pine around my windows cause its old and pealing and want to install rough cedar and stain it . when you stain do you need to use some kind of primer first aswell ? also should the entire piece of wood be stained back and front ?
